Subject: Re: Set env var for target when building
Date: Tue, 17 Jan 2017 00:58:58 +0000
For now what I am doing is hijacking the GNU_DIR variable in my <>/configure/os/CONFIG_SITE.Common.<target> in order to add the environment variable before the compiler.
Ugly but it is working so far.
On Mon, Jan 16, 2017 at 4:52 PM Hugo Slepicka <[email protected]> wrote:
Hi All,
I would like to set an environment variable to customize or disable CCACHE when building for a specific set of targets.
Where would be the correct place to do that?
Thank you,
Hugo
Re: Set env var for target when building Johnson, Andrew N.
Set env var for target when building Hugo Slepicka
Prev: Set env var for target when building Hugo Slepicka
Next: Re: Set env var for target when building Johnson, Andrew N.
