hello all,
I am designing an IOC for my serial device which is an keithley picoammeter. I am using Linux opensuse and EPICS base 3.14.12.5 and stream device. when I am connecting my device with usb/serial cable it works file. st.cmd for above setup is #!../../bin/linux-x86_64/K6485 ## You may have to change K6485 to something else ## everywhere it appears in this file epicsEnvSet("P","$(P=K6485:)") < envPaths epicsEnvSet("STREAM_PROTOCOL_ cd "${TOP}" ## Register all support components dbLoadDatabase "dbd/K6485.dbd" K6485_ ############################## dbLoadRecords "/home/pxbl21-1/programs/ # Set up ASYN ports # drvAsynIPPortConfigure port ipInfo priority noAutoconnect noProcessEos #drvAsynSerialPortConfigure(" asynSetTraceMask("L0",-1,0x09) asynSetOption("L0", -1, "baud", "9600") asynSetOption("L0", -1, "bits", "8") asynSetOption("L0", -1, "parity", "none") asynSetOption("L0", -1, "stop", "1") asynSetOption("L0", -1, "clocal", "Y") asynSetOption("L0", -1, "crtscts", "Y") asynOctetSetInputEos("L0", -1, "\r\n") asynOctetSetOutputEos("L0", -1, "\r\n") asynSetTraceIOMask("L0",-1, asynSetTraceMask("L0",-1,0x09) ############################## dbLoadRecords "db/devK6485.db" "P=$(P),R=1:,PORT=L0,A=-1, #dbLoadRecords "/home/pxbl21-1/programs/ ## Load record instances #dbLoadRecords("db/xxx.db"," cd "${TOP}/iocBoot/${IOC}" iocInit ## Start any sequence programs #seq sncxxx,"user=pxbl21-1Host" Now I want to connect my device through moxa 5150A board which is a Ethernet to serial converter having default IP address 192.168.127.254 I changed st.cmd and the error log is like -- #!../../bin/linux-x86_64/K6485 ## You may have to change K6485 to something else ## everywhere it appears in this file epicsEnvSet("P","K6485:") < envPaths epicsEnvSet("ARCH","linux-x86_64") epicsEnvSet("IOC","iocK6485") epicsEnvSet("TOP","/home/pxbl21-1/programs/epics/bl21/K6485") epicsEnvSet("ASYN","/home/pxbl21-1/programs/epics/modules/synApps_5_6/support/asyn-4-18") epicsEnvSet("STREAM","/home/pxbl21-1/programs/epics/modules/synApps_5_6/support/stream-2-5-1") epicsEnvSet("EPICS_BASE","/home/pxbl21-1/programs/epics/base-3.14.12.5") epicsEnvSet("STREAM_PROTOCOL_PATH","/home/pxbl21-1/programs/epics/bl21/K6485/db") cd "/home/pxbl21-1/programs/epics/bl21/K6485" ## Register all support components dbLoadDatabase "dbd/K6485.dbd" K6485_registerRecordDeviceDriver pdbbase ############################################################################## # Set up ASYN ports # drvAsynIPPortConfigure port ipInfo priority noAutoconnect noProcessEos #drvAsynSerialPortConfigure("L0","/dev/ttyUSB0",0,0,0) drvAsynIPPortConfigure("L0","192.168.127.254:4001",0,0,0) asynSetTraceMask("L0",0,0x09) #asynSetOption("L0", 0, "baud", "9600") #asynSetOption("L0", 0, "bits", "8") #asynSetOption("L0", 0, "parity", "none") #asynSetOption("L0", 0, "stop", "1") #asynSetOption("L0", 0, "clocal", "Y") #asynSetOption("L0", 0, "crtscts", "Y") #asynOctetSetInputEos("L0", 0, "\r\n") #asynOctetSetOutputEos("L0", 0, "\r\n") asynSetTraceIOMask("L0",0,0x2) asynSetTraceMask("L0",0,255) ############################################################################### dbLoadRecords "db/devK6485.db" "P=K6485:,R=1:,PORT=L0,A=0,NELM=1000" dbLoadRecords "/home/pxbl21-1/programs/epics/modules/synApps_5_6/support/asyn-4-18/db/asynRecord.db" "P=K6485:,R=asyn,PORT=L0,ADDR=0,OMAX=0,IMAX=0" ## Load record instances #dbLoadRecords("db/xxx.db","user=pxbl21-1Host") cd "/home/pxbl21-1/programs/epics/bl21/K6485/iocBoot/iocK6485" iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$ ## EPICS Base built Sep 15 2016 ############################################################################ 2017/01/18 16:13:59.525 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:16:06.248 asynManager connect queueCallback port:L0 2017/01/18 16:16:06.248 Open connection to 192.168.127.254:4001 reason:0 fd:-1 2017/01/18 16:16:26.243 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:13.480 L0 K6485:1:Measure: pasynCommon->connect() failed: Can't connect to 192.168.127.254:4001: Connection timed out 2017/01/18 16:18:13.480 asynManager connect queueCallback port:L0 2017/01/18 16:18:13.480 Open connection to 192.168.127.254:4001 reason:0 fd:-1 2017/01/18 16:18:13.480 _main_ K6485:1:Measure: @init handler failed 2017/01/18 16:18:13.480 _main_ K6485:1:Measure: Record initialization failed 2017/01/18 16:18:13.481 K6485:asyn: queueRequest failed 2017/01/18 16:18:13.481 K6485:asyn: queueRequest failed 2017/01/18 16:18:13.983 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:13.983 L0 schedule queueRequest timeout 2017/01/18 16:18:13.983 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:13.983 L0 schedule queueRequest timeout 2017/01/18 16:18:13.983 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:13.983 L0 schedule queueRequest timeout 2017/01/18 16:18:13.983 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:13.983 L0 schedule queueRequest timeout 2017/01/18 16:18:13.983 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:13.983 L0 schedule queueRequest timeout 2017/01/18 16:18:13.983 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:13.983 L0 schedule queueRequest timeout 2017/01/18 16:18:13.983 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:13.983 L0 schedule queueRequest timeout 2017/01/18 16:18:13.983 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:13.983 L0 schedule queueRequest timeout 2017/01/18 16:18:13.983 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:13.983 L0 schedule queueRequest timeout 2017/01/18 16:18:13.983 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:13.983 L0 schedule queueRequest timeout iocRun: All initialization complete ## Start any sequence programs #seq sncxxx,"user=pxbl21-1Host" epics> 2017/01/18 16:18:18.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:18.482 L0 schedule queueRequest timeout 2017/01/18 16:18:18.978 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:18.978 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:18.978 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:18.978 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:18.978 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:18.978 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:18.978 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:18.978 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:18.978 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:18.978 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:18.978 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:18.978 L0 schedule queueRequest timeout 2017/01/18 16:18:23.477 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:23.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:23.482 L0 schedule queueRequest timeout 2017/01/18 16:18:23.974 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:28.477 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:28.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:28.482 L0 schedule queueRequest timeout 2017/01/18 16:18:33.477 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:33.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:33.482 L0 schedule queueRequest timeout 2017/01/18 16:18:38.477 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:38.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:38.482 L0 schedule queueRequest timeout 2017/01/18 16:18:43.477 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:43.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:43.482 L0 schedule queueRequest timeout 2017/01/18 16:18:48.477 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:48.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:48.482 L0 schedule queueRequest timeout 2017/01/18 16:18:53.477 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:53.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:53.482 L0 schedule queueRequest timeout 2017/01/18 16:18:58.477 L0 asynManager:queueTimeoutCallback 2017/01/18 16:18:58.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:18:58.482 L0 schedule queueRequest timeout 2017/01/18 16:19:03.477 L0 asynManager:queueTimeoutCallback 2017/01/18 16:19:03.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:19:03.482 L0 schedule queueRequest timeout 2017/01/18 16:19:08.477 L0 asynManager:queueTimeoutCallback 2017/01/18 16:19:08.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:19:08.482 L0 schedule queueRequest timeout 2017/01/18 16:19:13.477 L0 asynManager:queueTimeoutCallback 2017/01/18 16:19:13.482 L0 addr -1 queueRequest priority 3 not lockHolder 2017/01/18 16:19:13.482 L0 schedule queueRequest timeout I did configuration for moxa, setting baudrate 9600 and operating mode -- TCP server. My RS232 is straight through. is there any problem in networking or I am missing something in IOC?? hoping for fast reply and solution. thanks in advance regards.. Sunny
ANJ, 21 Dec 2017 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
