Subject: RE: Problem compiling StreamDevice on Visual Studio 2015
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Thu, 19 Jan 2017 01:31:08 +0000
Hi Mark,
If you add some extra space around P I think it will work i.e.   result.print("%" P "d,%" P "d,%" P "d:\033[37m", offs, len, cap);
The additional spaces should not change the final string concatenation result
Freddie
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 19 January 2017 01:17
To: Mark Rivers; 'Dirk Zimoch'
I just found that P is defined as:
#define P PRINTF_SIZE_T_PREFIX
The format string was changed in this commit:
commit 73cba130c32df2031a3d862ed9daf5ba00d5173b
Author: zimoch <zimoch>
Date:   Thu May 16 08:28:34 2013 +0000
    use ssize_t for signed index types. Win has no ssize_t, use ptrdiff_t instead.
    use P instead of S as shortcut for PRINTF_SIZE_T_PREFIX because some OK already use S.
which did this:
-#define S PRINTF_SIZE_T_PREFIX
+#define P PRINTF_SIZE_T_PREFIX
-    result.print("%"S"d,%"S"d,%"S"d:\033[37m", offs, len, cap);
+    result.print("%"P"d,%"P"d,%"P"d:\033[37m", offs, len, cap);
But that does not tell me how to fix it.
Sent: Wednesday, January 18, 2017 7:09 PM
To: 'Dirk Zimoch'
Subject: Problem compiling StreamDevice on Visual Studio 2015
Hi Dirk and all,
The following line compiles OK on Visual Studio 2010, but fails on Visual Studio 2015:
This is the error:
cl -EHsc -GR                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344        -MT  -TP  -I. -I../O.Common -I.
-I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IJ:/epics/support/asyn-4-31/include   -IJ:/epics/support/calc-3-6-1/include
-IJ:/epics/support/sscan-2-10-2/include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        -c ../StreamBuffer.cc
StreamBuffer.cc
../StreamBuffer.cc(317): error C3688: invalid literal suffix 'P'; literal operator or literal operator template 'operator ""P' not found
H:/epics/base-3.15.5/configure/RULES_BUILD:233: recipe for target 'StreamBuffer.obj' failed
make[1]: *** [StreamBuffer.obj] Error 2
make[1]: Leaving directory 'J:/epics/support/stream/StreamDevice/src/O.windows-x64-static-vs2015'
H:/epics/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.windows-x64-static-vs2015' failed
make: *** [install.windows-x64-static-vs2015] Error 2
Can someone explain what the P characters in that format string do, and how to get this to compile on Visual Studio 2015?
RE: Problem compiling StreamDevice on Visual Studio 2015 Mark Rivers
Prev: RE: Problem compiling StreamDevice on Visual Studio 2015 Mark Rivers
Next: RE: Problem compiling StreamDevice on Visual Studio 2015 Mark Rivers
