1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Questions about set parameters to device by using epics
To: "'lzf neu'" <[email protected]>, "[email protected]" <[email protected]>, Eric Norum <[email protected]>
Date: Fri, 27 Jan 2017 18:40:00 +0000
R1-2 of Modbus and R4-9 of asyn are both 10 years old, and there have been many bug fixes since then, including on connection management.
I think if you want to get help from us you need to update to a more recent version of asyn and Modbus.
Sent: Friday, January 27, 2017 12:00 PM
To: Mark Rivers; [email protected]; Eric Norum
Cc: lzf neu
Subject:
答复: Questions about set parameters to device by using epics
Thanks for your reply, I correct the port.
However, the problem still exists.
I still cannot set new hour to device by using the db:
record(ao, "$(RPNAM):HourValSET"){
    field(DTYP,"asynInt32")
    field(OUT, "@asyn($(timeWDPORT),68)")
    field(SCAN,"Passive")
When starting epics, error messages display during its initialization (I mark the error lines as red color):
[rp@localhost iocTest]$ ./test.cmd
#!../../bin/linux-x86_64/modbusApp
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocTest")
epicsEnvSet("TOP","/home/rp/epicswork/modbusR1-2")
epicsEnvSet("EPICS_BASE","/home/rp/epics/base-3.14.12.5")
epicsEnvSet("ASYN","/home/rp/epics/modules/asyn-4.9")
epicsEnvSet("GENSUB","/home/rp/epics/modules/genSubV1-6")
dbLoadDatabase("../../dbd/modbus.dbd")
modbus_registerRecordDeviceDriver(pdbbase)
# Use the following commands for TCP/IP
#read   Device ID 2
drvAsynIPPortConfigure("AGM16-007",   "192.168.1.241:502",0,1,1)
modbusInterposeConfig("AGM16-007",  2,0,2000)
# Read 100 words (1600 bits).  Function code=3.
drvModbusAsynConfigure("RD1R",   "AGM16-007",  3, 0, 95, 0, 1130, "rpDevice")
# Write 8 words (128 bits).  Function code=16
drvModbusAsynConfigure("parawrite1", "AGM16-007", 16, 48, 8, 0, 10000, "rpDevice")
2017/01/28 01:29:00.964 drvModbusAsyn::doModbusIO port parawrite1 is disconnected
drvModbusAsynConfigure("timewrite1", "AGM16-007", 16, 64, 7, 0, 10000, "rpDevice")
dbLoadRecords("../../db/ssrfdb/RPmodbus.db","RPNAM=DCLS:RP:Gamma:01, PORT=RD1R,  paraWDPORT=parawrite1,  timeWDPORT=timewrite1")
iocInit
Starting iocInit
## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Jan 25 2017
2017/01/28 01:29:02.938  timewrite1 68 autoConnect could not connect
2017/01/28 01:29:02.938 asynManager::asynConnectCallback, port timewrite1 error calling asynCommon->connect
epics>
Any help will appreciated !
发件人: Mark Rivers <[email protected]>
发送时间: 2017127 11:50
收件人: lzf neu; Eric Norum; [email protected]
主题: RE: Questions about set parameters to device by using epics
Hi Zhefu,
> This is the db that I try to write Hour to device:
>    field(OUT, "@asyn($(PORT), 68)")
You are using the wrong port in HourValSET record.  The line should be
field(OUT, "@asyn($( timeWDPORT), 68)")
Port $(PORT) was assigned to RD1R which is Modbus function 3.
From: [email protected] [[email protected]] on behalf of lzf neu [[email protected]]
Sent: Thursday, January 26, 2017 11:34 PM
To: Eric Norum; [email protected]
Subject:
Firstly, thanks for your respond !
But the problem still exists, let me describe it in details.
The modbus version is R1-2(very old version).
And the contents of st.cmd file are posted in the following:
< envPaths
#read   Device ID 2
dbLoadRecords("../../db/ssrfdb/RPmodbus.db","RPNAM=Gamma:01, PORT=RD1R,  paraWDPORT=parawrite1,  timeWDPORT=timewrite1")
iocInit
After running, epics displays the following errors during its initialization:
2017/01/27 12:55:21.149 drvModbusAsyn::doModbusIO port parawrite1 is disconnected
Here is the whole messages:
< envPaths
#read   Device ID 2
iocInit
Starting iocInit
epics>
Now I can read data from device, but the problem is I cannot set parameters to device.
for example, I can read Hour from device in addr 68, but i cannot write new hour to device using the db.
This is the correct db that read Hour from device:
record(ai, "$(RPNAM):HourVal"){
    field(INP, "@asynMask($(PORT) 68 16)MODBUS_DATA")
    field(FLNK, "$(RPNAM):WeekVal")
by typing the command to set new hour value '15':
caput Gamma:01:HourValSET 15
The error message displays in the following:
epics> 2017/01/27 12:56:04.314 drvModbusAsyn::writeInt32 port RD1R invalid request for Modbus function 3
2017/01/27 12:56:04.314 DCLS:RP:Gamma:01:HourValSET devAsynInt32 process error
Any suggestions and many thanks in advance !
Zhefu
发件人: Eric Norum <[email protected]>
发送时间: 2017126 17:57
收件人: lzf neu
抄送: [email protected]
主题: Re: Questions about set parameters to device by using epics
You need to specify a MODBUS output function code ― function code 6 to write a single holding register, function code 16 to write multiple holding registers.  Here re a couple examples
drvModbusAsynConfigure("eps1_io", "epsPLC_1", 0, 6, 16000,   1, 0, 1000, "Wago")
drvModbusAsynConfigure("eps1_ao", "epsPLC_1", 0,16, 17216,  54, 0, 1000, "Wago”)
On Jan 26, 2017, at 9:42 AM, lzf neu <[email protected]<mailto:[email protected]>> wrote:
Below is the correct db that can read hour from the device:
now, I want to set new hour to the device and I try to write the following db according to Analog Output Example Record from "asynDriver: Asynchronous Driver Support" manual:
however, I failed, epics gives the following error messages:
Could anyone give me some suggestions and thanks in advance !
Questions about set parameters to device by using epics lzf neu
Re: Questions about set parameters to device by using epics Eric Norum
答复: Questions about set parameters to device by using epics lzf neu
RE: Questions about set parameters to device by using epics Mark Rivers
Prev: 答复: Questions about set parameters to device by using epics lzf neu
Next: macro question Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Next: monitor subscription in areaDetector Pearson, Matthew R.
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
