Subject: problem compiling edm
To: <[email protected]>
Date: Thu, 2 Feb 2017 14:15:49 +0000
I've a new pc on which I'm running Fedora release 25. I'm using base 3.15.5.
I'm attempting to build edm, but whilst attempting to compile, I get:
make[2]: Entering directory '/home/epics/epicsDEV/extensions/src/edm/lib/O.linux-x86_64' /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DSINGLE_THREADED=1 -D__epics__=1 -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/edm/compiler/gcc -I../../../../include/edm/os/Linux -I../../../../include/edm -I/home/epics/epicsDEV/base/include/compiler/gcc -I/home/epics/epicsDEV/base/include/os/Linux -I/home/epics/epicsDEV/base/include -I/home/epics/epicsDEV/extensions/include -I../../util -I../../lib -I/usr/include -I/usr/include -c ../cursor.cc ../cursor.cc: In member function ‘void cursorClass::create(Display*, Window, Colormap)’: ../cursor.cc:82:50: error: narrowing conversion of ‘224’ from ‘int’ to ‘char’ inside { } [-Wnarrowing]
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
../cursor.cc:82:50: error: narrowing conversion of ‘224’ from ‘int’ to ‘char’ inside { } [-Wnarrowing] ../cursor.cc:82:50: error: narrowing conversion of ‘224’ from ‘int’ to ‘char’ inside { } [-Wnarrowing]
and many more lines of the same.
I can't find this problem in tech-talk, nor with a web search. Has anyone run into this problem and if so, how did you resolve it?
Many thanks,
Pierrick
RE: problem compiling edm Mark Rivers
FW: problem compiling edm Sinclair, John William
Prev: RE: synApps and external sequencer installation Mark Rivers
Next: RE: problem compiling edm Mark Rivers
Prev: Re: synApps and external sequencer installation Luca Cavalli
