Subject: Re: Command omsMAXnetConfig not found
To: Kevin Peterson <[email protected]>
Cc: [email protected]
Date: Fri, 3 Feb 2017 10:27:55 -0800
OK, thanks for the heads up.
On Feb 3, 2017 9:41 AM, "Kevin Peterson" <[email protected]> wrote:
David,
You may run into problems caused by noise on the limit lines of the
motors controlled by the MAXnet.  I incorrectly assumed it had the same
internal filters as the MAXv.  Here is the info I received from OMS on
the subject:
  "The MAXv has a DS14C89 line driver which has internal filters.  The
MAXnet does not utilize the DS14C89 driver."
I'm still waiting for a fix from ACS to add filters to the limit lines
of their SPI-MAXnet-8000.  It is mostly unusable in its default state.
Kevin
Command omsMAXnetConfig not found David Vine
Re: Command omsMAXnetConfig not found Kevin Peterson
Re: Command omsMAXnetConfig not found David Vine
Prev: Re: Command omsMAXnetConfig not found Kevin Peterson
Next: Using synApps calc in simple IOC Iain Marcuson
