Subject: Epic-modbus build error
To: [email protected]
Date: Sat, 4 Feb 2017 22:23:00 -0800
Hi All,
I'm a new Epic user and have successfully installed epic-base and asyn. however, I encounter the below error when i run make from the top directory of epic-modbus. Any advise on it.
Thank you
Lanre Ogunmola
Graduate Research Affiliate
University of Nebraska, Omaha
make -C ./configure install
make[1]: Entering directory '/home/steal/modbus-master/configure'
perl /home/steal/base-3.14.12.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/steal/modbus-master/configure/O.linux-x86_64'
perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/home/steal/modbus-master/configure/O.linux-x86_64'
make[1]: Leaving directory '/home/steal/modbus-master/configure'
make -C ./modbusApp install
make[1]: Entering directory '/home/steal/modbus-master/modbusApp'
make -C ./src install
make[2]: Entering directory '/home/steal/modbus-master/modbusApp/src'
perl /home/steal/base-3.14.12.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/home/steal/modbus-master/modbusApp/src/O.linux-x86_64'
echo "../O.Common/modbus.dbd : ../Makefile" >> modbus.dbd.d
Expanding dbd
/home/steal/base-3.14.12.5/bin/linux-x86_64/dbExpand   -I. -I.. -I../O.Common -I../../../dbd -I/home/steal/asyn-master/dbd -I/home/steal/base-3.14.12.5/dbd -o modbus.dbd ../modbusInclude.dbd
Installing created dbd file ../../../dbd/modbus.dbd
mkdir ../../../dbd
Installing dbd file ../../../dbd/modbusSupport.dbd
Installing generic include file ../../../include/drvModbusAsyn.h
mkdir ../../../include
/usr/bin/gcc -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include        ../drvModbusAsyn.c
/usr/bin/gcc -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include        ../modbusInterpose.c
/usr/bin/g++ -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include        ../testModbusSyncIO.cpp
/usr/bin/ar -rc    libmodbus.a         drvModbusAsyn.o modbusInterpose.o testModbusSyncIO.o
/usr/bin/ranlib libmodbus.a
/usr/bin/g++ -o libmodbus.so -shared -fPIC -Wl,-hlibmodbus.so -L/home/steal/asyn-master/lib/linux-x86_64 -L/home/steal/base-3.14.12.5/lib/linux-x86_64 -Wl,-rpath,/home/steal/asyn-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/base-3.14.12.5/lib/linux-x86_64        -m64                drvModbusAsyn.o modbusInterpose.o testModbusSyncIO.o   -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libmodbus.so
mkdir ../../../lib
mkdir ../../../lib/linux-x86_64
Installing library ../../../lib/linux-x86_64/libmodbus.a
perl /home/steal/base-3.14.12.5/bin/linux-x86_64/registerRecordDeviceDriver.pl ../O.Common/modbus.dbd modbus_registerRecordDeviceDriver /home/steal/modbus-master > modbus.tmp
mv modbus.tmp modbus_registerRecordDeviceDriver.cpp
/usr/bin/g++ -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include        modbus_registerRecordDeviceDriver.cpp
modbus_registerRecordDeviceDriver.cpp:478:12: warning: ‘done’ defined but not used [-Wunused-variable]
 static int done = Registration();
/usr/bin/g++ -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include        ../modbusMain.cpp
/usr/bin/g++ -o modbusApp  -L/home/steal/modbus-master/lib/linux-x86_64 -L/home/steal/asyn-master/lib/linux-x86_64 -L/home/steal/base-3.14.12.5/lib/linux-x86_64 -Wl,-rpath,/home/steal/modbus-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/asyn-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/base-3.14.12.5/lib/linux-x86_64        -m64                modbus_registerRecordDeviceDriver.o modbusMain.o   -lmodbus -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
Installing created file ../../../bin/linux-x86_64/modbusApp
mkdir ../../../bin
mkdir ../../../bin/linux-x86_64
make[3]: Leaving directory '/home/steal/modbus-master/modbusApp/src/O.linux-x86_64'
make[2]: Leaving directory '/home/steal/modbus-master/modbusApp/src'
make -C ./Db install
make[2]: Entering directory '/home/steal/modbus-master/modbusApp/Db'
mkdir O.Common
make[3]: Entering directory '/home/steal/modbus-master/modbusApp/Db/O.linux-x86_64'
Installing template file ../../../db/bi_word.template
mkdir ../../../db
Installing template file ../../../db/bo_word.template
Installing template file ../../../db/bi_bit.template
Installing template file ../../../db/bo_bit.template
Installing template file ../../../db/longin.template
Installing template file ../../../db/longout.template
Installing template file ../../../db/longinInt32.template
Installing template file ../../../db/longoutInt32.template
Installing template file ../../../db/mbbiDirect.template
Installing template file ../../../db/mbboDirect.template
Installing template file ../../../db/ai.template
Installing template file ../../../db/ai_average.template
Installing template file ../../../db/ao.template
Installing template file ../../../db/aiFloat64.template
Installing template file ../../../db/aoFloat64.template
Installing template file ../../../db/intarray_in.template
Installing template file ../../../db/intarray_out.template
Installing template file ../../../db/stringin.template
Installing template file ../../../db/stringout.template
Installing template file ../../../db/stringWaveformIn.template
Installing template file ../../../db/stringWaveformOut.template
Installing template file ../../../db/statistics.template
Installing template file ../../../db/asynRecord.template
Installing template file ../../../db/poll_delay.template
Installing template file ../../../db/poll_trigger.template
make[3]: Leaving directory '/home/steal/modbus-master/modbusApp/Db/O.linux-x86_64'
make[2]: Leaving directory '/home/steal/modbus-master/modbusApp/Db'
make[1]: Leaving directory '/home/steal/modbus-master/modbusApp'
make -C ./iocBoot install
make[1]: Entering directory '/home/steal/modbus-master/iocBoot'
make -C ./iocTest install
make[2]: Entering directory '/home/steal/modbus-master/iocBoot/iocTest'
perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl -a linux-x86_64 -t /home/steal/modbus-master envPaths
perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl -a linux-x86_64 -t /home/steal/modbus-master cdCommands
make[2]: Leaving directory '/home/steal/modbus-master/iocBoot/iocTest'
make[1]: Leaving directory '/home/steal/modbus-master/iocBoot'
Re: Epic-modbus build error Mark Rivers
Prev: RE: Using synApps calc in simple IOC Mooney, Tim M.
Next: Re: Epic-modbus build error Mark Rivers
