Subject: Re: edm 1-12.40 on epics 3.14.12
To: <[email protected]>
Date: Thu, 9 Feb 2017 14:35:36 +0000
On Thu, 2011-01-20 at 13:31 -0800, S. Banerian wrote:
> I have been in the process of testing out epics 3.14.12 on debian linux
> 2.6.32 kernel, gcc 4.4, libc 2.11.2, and have encountered an issue with
> edm versions 1-12-39 and 1-12-40 which I've been unable to explain.
>*snip*
> /usr/local/cnts/epics/extensions/lib/linux-x86/libEpics.so: undefined
> symbol: create_epicsPvPtr
For the benefit of any recent EDM users with this problem I have just spent much too much time tracking down the cause of the same message on a source build from base-3.14.12.5 and edm -1-12-103.  This was built on a VirtualBox image with 64 bit Linux Mint 18 Sarah.  As this is the only thread mentioning the problem I will add my solution:
I had made an error in my export of the EDMPVOBJECTS environment variable to the shell in which I was launching EDM.  Correctly exporting EDMPVOBJECTS resolved the problem for me (although my font definitions still need some work).
Bob Anderson, ISIS LINAC RF Section
STFC Rutherford Appleton Laboratory
Building R12, Room 15B
Harwell Science and Innovation Campus
DIDCOT
OX11 0QX
Telephone (Direct dial) 01235-567112
RAL Mobile 0779-504-6410
[email protected]
Prev: Re: S7plc driver - PV block receiving problems Dirk Zimoch
Next: Re: MCB-4B Motor WriteInt32 Errors Caleb Marshall
Prev: DENEX detector with FAST ComTec MCS6A digitzer Hartman, Steven M.
Next: VAL field in Motor record Default unit Matt Dentinger
