> When I mentioned "the latest release" from asyn, I meant the latest package from this link:
> http://www.aps.anl.gov/epics/modules/soft/asyn/
> which is asyn release R4-30, the same version that Marcin was using.
> After I did an asyn checkout from github I had no more compiling errors for area detector.
> I am assuming the master on github for asyn is release R4-31, correct?
ADCore R2-5 should build fine with asyn R4-30. However, the master branch of ADCore (soon to be released as R2-6) requires the master branch of asyn (soon to be released as R4-31).
Sent: Wednesday, February 15, 2017 3:06 AM
To: Mark Rivers; Marcin Lukaszewski; [email protected]
Subject: Re: Problem compiling areaDetector-2-5
Hello Mark,
Like I said, I am new to EPICS and it is probably my lack of knowledge
that gets in the way.
Unfortunately, I have not kept any logs from my failed trials to be more
specific about it.
for area detector. I am assuming the master on github for asyn is
Nilson
On 14.02.2017 19:02, Mark Rivers wrote:
>> My solution was to compile asyn from a git checkout instead if using the latest release.
> What do you mean by "using the latest release". I would like to know about any problems building areaDetector with either the master branch or any set of compatible tagged releases.
> Mark
> From: [email protected] [[email protected]] on behalf of Nilson Pereira [[email protected]]
> Sent: Tuesday, February 14, 2017 10:39 AM
> To: Marcin Lukaszewski; [email protected]
> Hello Marcin,
> I am new to EPICS and I am not sure I will be able to help. Anyway, recently, I had a lot of trouble compiling area detector as well. The compiling errors were different than yours but maybe they have the same source.
> This was my setup:
> Ubuntu 16.04 LTS
> EPICS Base R3.15.5
> Asyn R4-31 (Head of Master on git - 19.1.2017)
> Autosave R5.7.1
> Busy R1.6.1
> Calc R.3.61
> Sequencer R2.2.4
> SScan R2.10
> Area Detector R2.5 with modules (Head of Master on git - 19.1.2017):
> ADCore R2.5
> NDDriverStdArrays R1.0
> ADSupport R1.0
> That is quick to try and I hope it works.
> Nilson
> On 14.02.2017 17:00, Marcin Lukaszewski wrote:
> Hi all,
> I am trying to compile areaDetector R2-5 on Ubuntu 16.04 LTS
> I git clone areaDetector, ADCore, ADSupport and ADExample and git checkout to following versions:
> areaDetector R2-5
> ADCore R2-5
> ADSupport R1-0
> ADExample R2-2
> EPICS setup:
> base 3.15.4
> asyn-4-30
> autosave-5-7-1
> busy-1-6-1
> calc-3-4-2-1
> seq-2-23
> sscan-2-10-1
> Below pasties to my areaDetector/configure files:
> - areaDetector folder structure http://pastebin.com/5KmLn7Cb
> - RELEASE_PATHS.local http://pastebin.com/JbzKhrTE
> - RELEASE_LIBS.local http://pastebin.com/Eus4L5Fi
> - RELEASE_PRODS.local http://pastebin.com/gDSyG2JT
> - CONFIG_SITE.LOCAL http://pastebin.com/C7iumVfN
> - RELEASE.local http://pastebin.com/a0BsWNAs
> After setup above I am trying to make but compilation terminates with the error:
> /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DH5_NO_DEPRECATED_SYMBOLS -DH5Dopen_vers=2 -DH5Gcreate_vers=2 -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/eli_sw/epics/R3.15/include/compiler/gcc -I/home/eli_sw/epics/R3.15/include/os/Linux -I/home/eli_sw/epics/R3.15/include -I/home/eli_sw/epics/support/asyn-4-30/include -I/home/eli_sw/epics/support/areaDetector-2-5/ADCore/include -I/usr/local64/include -I/usr/include/libxml2 -c ../PosPluginWrapper.cpp
> In file included from ../PosPluginWrapper.cpp:8:0:
> ../PosPluginWrapper.h:11:25: fatal error: NDPosPlugin.h: No such file or directory
> compilation terminated.
> /home/eli_sw/epics/R3.15/configure/RULES_BUILD:234: recipe for target 'PosPluginWrapper.o' failed
> make[4]: *** [PosPluginWrapper.o] Error 1
> make[4]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp/pluginTests/O.linux-x86_64'
> /home/eli_sw/epics/R3.15/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
> make[3]: *** [install.linux-x86_64] Error 2
> make[3]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp/pluginTests'
> /home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target 'pluginTests.install' failed
> make[2]: *** [pluginTests.install] Error 2
> make[2]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp'
> /home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target 'ADApp.install' failed
> make[1]: *** [ADApp.install] Error 2
> make[1]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore'
> /home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target '/home/eli_sw/epics/support/areaDetector-2-5/ADCore.install' failed
> make: *** [/home/eli_sw/epics/support/areaDetector-2-5/ADCore.install] Error 2
> Full output you can find here: http://pastebin.com/y06WGJwX
> Quick check if I have files in correct places gives me:
> → find -name "NDPosPlugin.h"
> ./ADCore/ADApp/pluginSrc/NDPosPlugin.h
> → find -name "PosPluginWrapper.h"
> ./ADCore/ADApp/pluginTests/PosPluginWrapper.h
> What I am doing wrong? Is there anything else I have to setup to compile areaDetector?
> Marcin
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Postadresse:
D-14109 Berlin
- Problem compiling areaDetector-2-5 Marcin Lukaszewski
- Re: Problem compiling areaDetector-2-5 Nilson Pereira
- RE: Problem compiling areaDetector-2-5 Mark Rivers
Re: IOC Connecting Problem Rod Nussbaumer
<2017>
Re: Problem compiling areaDetector-2-5 Andrew Johnson
<2017>
