I visit the directory /extensions/src/edm/setup/ and run ./setup.sh to compile EDM, an error occured and gives the following information:
Edm component file is /home/user/epics/extensions/src/edm/setup/edmObjects
/home/user/epics/extensions/src/edm/imagelib/O.linux-x86_64/lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory
When running EDM, the software cannot display pictures and gives the following error messages:
Error creating object "activePngClass"
Error creating object "cfcf6c8a_dbeb_11d2_8a97_00104b8742df"
However, I have already installed giflib, giflib-devel, libNX_Xtst, libXtst, libXtst-devel packages and set env .
export EDMBASE=/home/user/epics/extensions/src/edm
export EDMPVOBJECTS=/home/user/epics/extensions/src/edm/setup
export EDMOBJECTS=/home/user/epics/extensions/src/edm/setup
export EDMHELPFILES=/home/user/epics/extensions/src/edm/helpFiles
export EDMFILES=/home/user/epics/extensions/src/edm/edmMain
Do I miss something?
Could you give me some advice thanks in advance.
