Subject: RE: Question about PV operation that defined in ai.template.
To: lzf neu <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 24 Feb 2017 04:45:34 +0000
The problem is these lines:
  field (FLNK, "REMS-ARSM:Neutron:ChangeUnit001")
  field (FLNK, "REMS-ARSM:Neutron:ChangeUnit002")
  field (FLNK, "REMS-ARSM:Gamma:ChangeUnit003")
Each record only has a single FNLK field, you cannot repeat this line.  I think it will use the last FLNK line, so I suspect that REMS-ARSM:Gamma:ChangeUnit003 has processed, but REMS-ARSM:Gamma:ChangeUnit001 and REMS-ARSM:Gamma:ChangeUnit002 have not.
If you want to process all 3 records then you need to do this:
#====================ai.tempalte========================
# ai record template
record (ai, "$(P)-$(S):$(NAME)$(NUM)")
  field (DTYP, "lrpApp")
  field (INP,  "@Monitor:$(INDEX)/$(OFFSET) L=$(LENGTH)")
  field (ASLO,"$(ASLO)")
  field (LINR, "LINEAR")
  field (SCAN, "I/O Intr")
  field (HIHI, "$(HIHI)")
  field (LOLO, "$(LOLO)")
  field (HIGH,"$(HIGH)")
  field (LOW,"$(LOW)")
record (calc, "REMS-ARSM:Neutron:ChangeUnit001")
        field(INPA, "REMS-ARSM:AlphaCountRate001.VAL")
        field(CALC, "A*0.1")
        field(EGU,  "uSv/h")
record (calc, "REMS-ARSM:Neutron:ChangeUnit002")
        field(INPA, "REMS-ARSM:AlphaCountRate002.VAL")
        field(EGU,  "uSv/h")
record (calc, "REMS-ARSM:Gamma:ChangeUnit003")
        field(INPA, "REMS-ARSM:AlphaCountRate003.VAL")
        field(EGU,  "uSv/h")
So each record has a forward link to the next record.
From: [email protected] [[email protected]] on behalf of lzf neu [[email protected]]
Sent: Thursday, February 23, 2017 10:09 PM
To: [email protected]
Subject: Question about PV operation that defined in ai.template.
    I want to make an operation on part of PV that defined in ai.template. (namely:EMS-ARSM:Neutron:ChangeUnit001, EMS-ARSM:Neutron:ChangeUnit002,EMS-ARSM:Gamma:ChangeUnit001 )
    So, I add operation field in ai.template and also copy the file to Db folder and recompiled again.
    I have posted ai.template in the following lines:
        field(EGU,  "uSv/h")
        field(EGU,  "uSv/h")
        field(EGU,  "uSv/h")
#====================end of ai.tempalte=====================
here is the content of REMS_ARSM.substitutions (load "ai.template") file that used in st.cmd file to launch the IOC:
#=========================REMS_ARSM.substitutions================
file "db/ai.template" { pattern
{P,      S,       NAME,             NUM,    INDEX,      OFFSET,     LENGTH,      ASLO,     HIHI,             HIGH,               LOLO,         LOW}
{REMS, ARSM,     AlphaCountRate,    001,      21,        100,          5,        0.1,        50,              20,                 3,             0}
#====================end of REMS_ARSM.substitutions================
However, when started IOC I failed to do the operation and the result dislpayed in terminal:
epics> dbpr REMS-ARSM:Neutron:ChangeUnit001
A: 0                ASG:                B: 0                C: 0
CALC: A*0.1         D: 0                DESC:               DISA: 0
DISP: 0             DISV: 1             E: 0                F: 0
G: 0                H: 0                I: 0                J: 0
K: 0                L: 0                NAME: REMS-ARSM:Neutron:ChangeUnit001
SEVR: INVALID       STAT: UDF           TPRO: 0             VAL: 0
Could you give me some suggestions and thanks in advance !
Zhefu
Question about PV operation that defined in ai.template. lzf neu
Prev: Question about PV operation that defined in ai.template. lzf neu
Next: Re: memory leak after unloading of ca.lib Carsten Winkler
Next: streamDevice protocol - accept two different valid responses James.OHea
