1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: CaQtDM installation error on scientific linux 7.2
To: tech-talk <[email protected]>
Date: Mon, 6 Mar 2017 13:30:09 +0530 (IST)
I am facing a problem while installing caQtDM on a sl7.2 after properly setting the environment variables  and making it. Below is the error shown:
CaQtDM Error:
lQt5Core -lGL
/bin/ld: cannot find -lCom
/bin/ld: /usr/local/lib/libpython2.7.a(abstract.o): relocation R_X86_64_32S against `_Py_NotImplementedStruct' can not be used when making a shared object; recompile with -fPIC
/usr/local/lib/libpython2.7.a: error adding symbols: Bad value
collect2: error: ld returned 1 exit status
make[1]: *** [/usr/lib64/epics/extensions/src/caqtdm-4.1.3/caQtDM_Binaries/libcaQtDM_Lib.so] Error 1
make[1]: Leaving directory `/usr/lib64/epics/extensions/src/caqtdm-4.1.3/caQtDM_Lib'
make: *** [sub-caQtDM_Lib-make_first] Error 2
Please Suggest any solution to this!!
Thanks
 Arnab
Prev: RE: RE: RE: RE: Re: IOC Connecting Problem Pilkyu Jung
Next: BURT error while execution Arnab Dasgupta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Problem with EPICS Ralph Lange
Next: Re: CaQtDM installation error on scientific linux 7.2 Mezger Anton Christian (PSI)
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
