1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Asyn 4-30 Problem on Arm processor
To: 'Jörn Dreyer' <[email protected]>
Cc: Epics <[email protected]>
Date: Thu, 16 Mar 2017 19:26:44 +0000
Hi Jörn
I think the following output shows a problem:
HAM1 multiDevice:No canBlock:No autoConnect:No
   enabled:Yes connected:No numberConnects 0
   nDevices 0 nQueued 0 blocked:No
   asynManagerLock:No synchronousLock:No
   exceptionActive:No exceptionUsers 0 exceptionNotifys 0
   traceMask:0x1f traceIOMask:0x1f traceInfoMask:0x1
It says connected:No and autoConnect:No.  This means your records won’t be able to connect to the device at iocInit, so they better not process.
Is this what you intend?  Why is the device not showing as connected after you call HamamatsuC11204_02AsynPortDriverConfigure()?
Sent: Thursday, March 16, 2017 10:40 AM
To: Mark Rivers
Cc: Epics
Subject: Re: Asyn 4-30 Problem on Arm processor
Hi Mark,
here is the output of my IOC with asyn4-31 now. I noticed this morning that there is a new version and neede to recompile my code.
#!../../bin/linux-arm/crpc
< envPaths_raspi
epicsEnvSet("ARCH","linux-arm")
epicsEnvSet("IOC",raspi01)
epicsEnvSet("TOP","/home/fwkk_scs/Epics/app")
epicsEnvSet("SNCSEQ","/home/fwkk_scs/Epics/seq-2.2.2")
epicsEnvSet("EPICS_BASE","/home/fwkk_scs/Epics/base-3.14.12.5")
epicsEnvSet("ASYN","/home/fwkk_scs/Epics/modules/asyn4-26")
epicsEnvSet("STREAM_PROTOCOL_PATH","/home/fwkk_scs/Epics/app/protocols")
epicsEnvSet("MOTOR","/home/fwkk_scs/Epics/modules/motorR6-9")
epicsEnvSet("NETSNMP","/home/scs/Epics/modules/snmp")
epicsEnvSet("MIBDIRS","/usr/share/mibs/ietf:/home/fwkk_scs/Epics/app/protocols")
epicsEnvSet("WCR_PREF","guru WIENER-CRATE-MIB::")
cd /home/fwkk_scs/Epics/app
dbLoadDatabase "dbd/crpc.dbd"
crpc_registerRecordDeviceDriver pdbbase
# Setup for HAMAMATSU power supply
HamamatsuC11204_02AsynPortDriverConfigure("HAM1","/dev/ttyUSB0",0)
asynSetTraceMask("HAM1",0,0x1f)
asynSetTraceIOMask("HAM1",0,0x1f)
dbLoadRecords "db/Hamamatsu_C11204.db"
dbLoadRecords ("db/iocAdminSoft.db", "IOC=raspi01")
dbLoadRecords ("db/iocAdminScanMon.db", "IOC=raspi01")
## Run this to trace the stages of iocInit
#traceIocInit
asynReport 1
Port: HAM1
 Timestamp: <undefined>
 Input EOS[0]:
 Output EOS[0]:
Parameter list 0
Number of parameters is: 19
Parameter 0 type=asynFloat64, name=SECOND_SIDE_HIGH_TEMP_CORR_FACTOR, value is undefined
Parameter 1 type=asynFloat64, name=SECOND_SIDE_LOW_TEMP_CORR_FACTOR, value is undefined
Parameter 2 type=asynFloat64, name=PRIMARY_SIDE_HIGH_TEMP_CORR_FACTOR, value is undefined
Parameter 3 type=asynFloat64, name=PRIMARY_SIDE_LOW_TEMP_CORR_FACTOR, value is undefined
Parameter 4 type=asynFloat64, name=REFERENCE_VOLTAGE, value is undefined
Parameter 5 type=asynFloat64, name=REFERENCE_TEMPERATURE, value is undefined
Parameter 6 type=asynInt32, name=STATUS_READ, value is undefined
Parameter 7 type=asynFloat64, name=VOLTAGE_READ, value is undefined
Parameter 8 type=asynFloat64, name=CURRENT_READ, value is undefined
Parameter 9 type=asynFloat64, name=TEMPERATURE_READ, value is undefined
Parameter 10 type=string, name=DEVICE_NAME_READ, value is undefined
Parameter 11 type=string, name=DEVICE_VERSION_READ, value is undefined
Parameter 12 type=string, name=DEVICE_BUILD_DATE_READ, value is undefined
Parameter 13 type=asynInt32, name=HV_OUTPUT_ON, value is undefined
Parameter 14 type=asynInt32, name=HV_OUTPUT_OFF, value is undefined
Parameter 15 type=asynInt32, name=RESET, value is undefined
Parameter 16 type=asynInt32, name=SET_TEMP_COMP_MODE, value is undefined
Parameter 17 type=asynInt32, name=MODE_WRITE, value is undefined
Parameter 18 type=asynInt32, name=MODE_READ, value is undefined
cd /home/fwkk_scs/Epics/app/iocBoot/ioccrpc
iocInit
Starting iocInit
## EPICS R3.15.5
## EPICS Base built Mar  3 2017
2017/03/16 16:37:50.614 HAM1 asynManager::queueLockPort locking port
Segmentationfault
Jörn
Re: Asyn 4-30 Problem on Arm processor Jörn Dreyer
RE: Asyn 4-30 Problem on Arm processor Mark Rivers
Prev: Re: Asyn 4-30 Problem on Arm processor Jörn Dreyer
Next: Re: Streamdevice: wild card in InTerminator? Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Asyn 4-30 Problem on Arm processor Jörn Dreyer
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
