Subject: Re: INP string length
To: "Konrad, Martin" <[email protected]>, "Siddons, David" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 29 Mar 2017 10:33:04 -0400
On 03/28/2017 11:28 PM, Konrad, Martin wrote:
> Hi Pete,
> On 03/28/2017 10:51 PM, Siddons, David wrote:
>> Back in 2010 I found this comment from Michael Davidsaver:
>>> One of the limitations on the length of INP or OUT is dbPutString
>>> in dbStaticLib.c (search for 'string[80]').  When you reach this
>>> limit you will see the message "dbPutString received a string that
>>> is too long". Do you see this?
>> Well, yes, I do :) Has there been any changes in this behavior since
>> then?
> Yes. Search for "Raised limit on link field length in database files" in
> [1] for more details.
This length limitation is removed entirely in the 3.16 series.
Re: INP string length Konrad, Martin
Prev: Re: Question about PV name by using pcaspy Kasemir, Kay
Next: Re: memory leak after unloading of ca.lib Xiaoqiang Wang
Prev: Re: INP string length Konrad, Martin
Next: Question about PV name by using pcaspy lzf neu
