Subject: 答复: Question about PV name by using pcaspy
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 30 Mar 2017 15:45:42 +0000
Thank you!
I have a new question to consult you:
I want to get the return value of caget('some PV name') by writing Pcaspy script. I have no idear what command to use in the script.
Any suggestions will be appreciated !
发件人: Kasemir, Kay <[email protected]>
发送时间: 2017年3月29日 12:46:30
收件人: lzf neu
抄送: [email protected]
主题: Re: Question about PV name by using pcaspy
On Mar 29, 2017, at 3:37 AM, lzf neu <[email protected]> wrote:
I want to fulfill a goal that when running camonitor command, PV name TEST:PING in the terminal window print "Disconnect!" or "OK!" alternatively.
However, I failed, "self.setParam('PING',a)"  seems only run once in the code and in terminal window only print one result.
I have posted the code in the following lines.
Could you give me some suggestions and any help will be appreciated.
You’re missing a call to
   self.updatePVs()
-Kay
Zhefu
#!/usr/bin/env python
import os
import threading
import time
from pcaspy import Driver, SimpleServer
prefix = 'TEST:'
pvdb = {
    'PING' : {
         'type':'enum',
         'enums':['Disconnect!','OK!']
class myDriver(Driver):
    def __init__(self):
        super(myDriver, self).__init__()
        tid=threading.Thread(target=self.determine)
        tid.setDaemon(True)
        tid.start()
    def determine(self):
        a=os.system("ping -c 1 -w 1 127.0.0.1")
        if (a==0):
          while True:
             a=not a
             time.sleep(5)
if __name__ == '__main__':
    server = SimpleServer()
    server.createPV(prefix, pvdb)
    driver = myDriver()
    # process CA transactions
    while True:
        server.process(0.1)
Re: Question about PV name by using pcaspy Xiaoqiang Wang
Question about PV name by using pcaspy lzf neu
Re: Question about PV name by using pcaspy Kasemir, Kay
Prev: Re: memory leak after unloading of ca.lib Xiaoqiang Wang
Next: PCAS (using pcaspy) in docker ""server isnt attached to a network" Sparger, John E.
Prev: Re: Question about PV name by using pcaspy Kasemir, Kay
Next: Re: Question about PV name by using pcaspy Xiaoqiang Wang
