Subject: Re: Data type problem in EPICS PV
To: <[email protected]>
Date: Mon, 8 May 2017 10:50:09 -0500
Hi Palak,
Nobody is going to be able to help you without more information. Is this
PV coming from an IOC (which version of Base, what device support are
you using to connect to the PLC, what kind of PLC, what does the record
definition look like), or from some other kind of CA server such as pcaspy?
http://www.catb.org/esr/faqs/smart-questions.html#beprecise
- Andrew
On 05/08/2017 05:08 AM, palak shimpee wrote:
> EPICS PV named “CWS-TXX-F000:mode_request” with INT32 datatype is
> deployed on PLC . Using move instruction in SIMATIC Manager, -1 value is
> passed to DB7.DBW6 with integer datatype. Through this DB7.DBW6 the
> value is passed in “CWS-TXX-F000:mode_request”. But the value being
> updated in “CWS-TXX-F000:mode_request” is 65535. Can I get a solution
> for this?
Data type problem in EPICS PV palak shimpee
Prev: Re: Troubleshoot "Appliance Down" Issue in EPICS Archiver Applianc Shankar, Murali
Next: AreaDetector bindings and RBV propagation Iain Marcuson
Prev: Data type problem in EPICS PV palak shimpee
Next: Re: Troubleshoot "Appliance Down" Issue in EPICS Archiver Applianc Shankar, Murali
