Subject: Re: Question about Edm dynamic display zone's fill color according to PVs
To: lzf neu <[email protected]>, tech_talk <[email protected]>
Date: Tue, 9 May 2017 09:53:57 -0700
Hi Zhefu,
--- in the edmobjects directory in the colors.list file you need to define static colors (I just chose the indices 0,1,2,3,...):
static 0 blue { 0 0 65535 }
static 1 green-yellow { 0 65535 0 65535 65535 0 }
static 2 green-red { 0 65535 0 65535 0 0 }
rule 3 zone-fill {
 = 1 : blue
 = 2 : green-yellow
 = 3 : green-red
 default: blue
---  in the edmobjects directory in the calc.list file you need to define a calculated color:
zone-fill
A=1&&B=1?2:(A=0&&B=1&&C=1?3:1)
--- in your edm widget, e.g. a rectangle
set the fill-color to
zone-fill
set the Color PV to
CALC\zone-fill(PVa,PVb,PVc)
- rolf -
On 05/09/17 03:32, lzf neu wrote:
I want to display the zone's fill color according to PVs.
In my case, rectangle zone's fill color depend on three PVs.
Let's assume PVa, PVb and PVc.
If PVc is equal to zero, then the rectangle's fill color is blue.
If PVa and PVb are both equal to 1, the rectangle zone's fill color is green and yellow blittering alternatively.
if PVa is 0 and PVb and PVc are both 1, then the zone's fill color is green and red blittering alternatively.
I have no idea how to do this by using edm, any help will be appreciated and thanks in advance.
Zhefu
Question about Edm dynamic display zone's fill color according to PVs lzf neu
Prev: RE: V4 question. Mark Rivers
Next: First Release Candidate of Base-3.16.1 Andrew Johnson
Prev: Question about Edm dynamic display zone's fill color according to PVs lzf neu
Next: Re: V4 question. Andrew Johnson
