Subject: RE: EPICS CPP 4.6.0 Build Error
To: 'David Vine' <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 10 May 2017 23:02:16 +0000
Hi David,
I think this is the same problem that occurs on Visual Studio 2015.
I have attached the patch which fixes the problem.  I have also appended to the message since I think tech-talk does not archive atttachments.
I think this problem should go on the known problems page for V4 4.6.0.
http://epics-pvdata.sourceforge.net/docbuild/4.6.0/issues.html#c++_module_issues
--- examplePvaClientPut.cpp.orig     2017-01-22 08:04:18.253673488 -0600
+++ examplePvaClientPut.cpp     2017-01-22 08:04:18.253673488 -0600
@@ -32,13 +32,14 @@
     PvaClientMonitorPtr monitor = pva->channel(channelName,providerName,2.0)->monitor("value");
     PvaClientMonitorDataPtr monitorData = monitor->getData();
     putData->putDouble(3.0); put->put();
-    cout <<  channel->get("field(value)")->getData()->showChanged(cout) << endl;
+    channel->get("field(value)")->getData()->showChanged(cout) << endl;
     putData->putDouble(4.0); put->put();
     if(!monitor->waitEvent()) {
            cout << "waitEvent returned false. Why???";
     } else while(true) {
-         cout << "monitor changed\n" << monitorData->showChanged(cout);
+         cout << "monitor changed" << endl;
+         monitorData->showChanged(cout);
          monitor->releaseEvent();
          if(!monitor->poll()) break;
@@ -56,15 +57,16 @@
     shared_vector<double> data(num,0);
     for(size_t i=0; i<num; ++i) data[i] = .1*i;
     putData->putDoubleArray(freeze(data)); put->put();
     data = "">
     for(size_t i=0; i<num; ++i) data[i] = .1*(i + 1);
@@ -79,9 +81,9 @@
     PvaClientPutDataPtr putData = put->getData();
     PVScalarPtr pvScalar = static_pointer_cast<PVScalar>(putData->getValue());
     convert->fromDouble(pvScalar,1.0); put->put();
     convert->fromDouble(pvScalar,2.0); put->put();
--- examplePvaClientProcess.cpp.orig 2017-01-22 08:04:32.577562268 -0600
+++ examplePvaClientProcess.cpp 2017-01-22 08:04:32.573562299 -0600
@@ -25,9 +25,9 @@
     PvaClientChannelPtr channel = pva->channel("PVRdouble");
     PvaClientProcessPtr process = channel->createProcess();
     process->process();
-    cout <<  channel->get("field()")->getData()->showChanged(cout) << endl;
+    channel->get("field()")->getData()->showChanged(cout) << endl;
     process->process();
From: [email protected] [mailto:[email protected]] On Behalf Of David Vine
Sent: Wednesday, May 10, 2017 5:37 PM
To: [email protected]
Subject: EPICS CPP 4.6.0 Build Error
Hi all,
I was trying to compile v4 for the first time and I get some build errors (see below). I copied the whole build output below and reproduced just the error messages at the top.
Any suggestions on how to fix this error?
David
[david@dusk ~]$ uname -a
Linux dusk 4.10.13-1-ARCH #1 SMP PREEMPT Thu Apr 27 12:15:09 CEST 2017 x86_64 GNU/Linux
[david@dusk ~]$ g++ --version
g++ (GCC) 6.3.1 20170306
../examplePvaClientProcess.cpp:28:10: error: no match for ‘operator<<’ (operand types are ‘std::ostream {aka std::basic_ostream<char>}’ and ‘std::ostream {aka std::basic_ostream<char>}’)
../examplePvaClientProcess.cpp:28:66: error: cannot bind ‘std::ostream {aka std::basic_ostream<char>}’ lvalue to ‘std::basic_ostream<char>&&’
../examplePvaClientProcess.cpp:30:10: error: no match for ‘operator<<’ (operand types are ‘std::ostream {aka std::basic_ostream<char>}’ and ‘std::ostream {aka std::basic_ostream<char>}’)
../examplePvaClientProcess.cpp:30:66: error: cannot bind ‘std::ostream {aka std::basic_ostream<char>}’ lvalue to ‘std::basic_ostream<char>&&’
[david@dusk EPICS-CPP-4.6.0]$ make
make -C pvCommonCPP all
make[1]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP'
make -C ./configure install
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/configure/O.linux-x86_64'
perl -CSD /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/configure/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/configure'
make -C ./boostApp install
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/boostApp'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/boostApp/O.linux-x86_64'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/boostApp/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/boostApp'
make -C ./mbSrc install
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/mbSrc'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/mbSrc/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/mbSrc/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/mbSrc'
make -C ./testApp install
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/testApp'
make -C ./boost install
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/testApp/boost'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/testApp/boost/O.linux-x86_64'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/testApp/boost/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/testApp/boost'
make -C ./mb install
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/testApp/mb'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/testApp/mb/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/testApp/mb/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/testApp/mb'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/testApp'
make[1]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP'
make -C pvDataCPP all
make[1]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/configure'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/configure/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/configure'
make -C ./src install
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/src'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/src/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/src/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/src'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/testApp'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/testApp/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/testApp/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/testApp'
make[1]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDataCPP'
make -C normativeTypesCPP all
make[1]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/configure'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/configure/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/configure'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/src'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/src/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/src/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/src'
make -C ./test install
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/test'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/test/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/test/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/test'
make[1]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP'
make -C pvAccessCPP all
make[1]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/configure'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/configure/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/configure'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/src'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/src/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/src/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/src'
make -C ./pvtoolsSrc install
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/pvtoolsSrc'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/pvtoolsSrc/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/pvtoolsSrc/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/pvtoolsSrc'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/testApp'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/testApp/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/testApp/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/testApp'
make[1]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP'
make -C pvaClientCPP all
make[1]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaClientCPP'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/configure'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/configure/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/configure'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/src'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/src/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/src/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/src'
make[1]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaClientCPP'
make -C pvaSrv all
make[1]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/configure'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/configure/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/configure'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/src'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/src/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/src/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/src'
make -C ./testTop install
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/configure'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/configure/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/configure'
make -C ./iocBoot install
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/iocBoot'
make -C ./testDbGroup install
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/iocBoot/testDbGroup'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/iocBoot/testDbGroup'
make -C ./testDbPv install
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/iocBoot/testDbPv'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/iocBoot/testDbPv'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/iocBoot'
make -C ./dbPv install
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/dbPv'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/dbPv/src'
make[5]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/dbPv/src/O.linux-x86_64'
make[5]: Nothing to be done for 'install'.
make[5]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/dbPv/src/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/dbPv/src'
make -C ./Db install
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/dbPv/Db'
make[5]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/dbPv/Db/O.linux-x86_64'
make[5]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/dbPv/Db/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/dbPv/Db'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop/dbPv'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/testTop'
make -C ./exampleTop install
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/configure'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/configure/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/configure'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/iocBoot'
make -C ./simpleDbPv install
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/iocBoot/simpleDbPv'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/iocBoot/simpleDbPv'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/iocBoot'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/simpleDbPv'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/simpleDbPv/src'
make[5]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/simpleDbPv/src/O.linux-x86_64'
make[5]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/simpleDbPv/src/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/simpleDbPv/src'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/simpleDbPv/Db'
make[5]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/simpleDbPv/Db/O.linux-x86_64'
make[5]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/simpleDbPv/Db/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/simpleDbPv/Db'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop/simpleDbPv'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv/exampleTop'
make[1]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvaSrv'
make -C pvDatabaseCPP all
make[1]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/configure'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/configure/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/configure'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/src'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/src/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/src/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/src'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/test'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/test/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/test/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/test'
make[1]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP'
make -C exampleCPP all
make[1]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP'
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/configure'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/configure/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/configure'
make -C ./database install
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/configure'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/configure/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/configure'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/src'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/src/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/src/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/src'
make -C ./ioc install
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/ioc'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/ioc/src'
make[5]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/ioc/src/O.linux-x86_64'
make[5]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/ioc/src/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/ioc/src'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/ioc/Db'
make[5]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/ioc/Db/O.linux-x86_64'
make[5]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/ioc/Db/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/ioc/Db'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/ioc'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/iocBoot'
make -C ./exampleDatabase install
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/iocBoot/exampleDatabase'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/iocBoot/exampleDatabase'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database/iocBoot'
make[2]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/database'
make -C ./exampleClient install
make[2]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/exampleClient'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/exampleClient/configure'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/exampleClient/configure/O.linux-x86_64'
make[4]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/exampleClient/configure/O.linux-x86_64'
make[3]: Leaving directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/exampleClient/configure'
make[3]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/exampleClient/src'
make[4]: Entering directory '/opt/epics/EPICS-CPP-4.6.0/exampleCPP/exampleClient/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/opt/epics/EPICS-CPP-4.6.0/pvDatabaseCPP/include   -I/opt/epics/EPICS-CPP-4.6.0/pvaSrv/include   -I/opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/include   -I/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/include   -I/opt/epics/EPICS-CPP-4.6.0/normativeTypesCPP/include   -I/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include   -I/opt/epics/EPICS-CPP-4.6.0/pvCommonCPP/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include        -c ../examplePvaClientProcess.cpp
In file included from /opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/include/pv/pvaClient.h:27:0,
                 from ../examplePvaClientProcess.cpp:14:
/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/include/pv/pvAccess.h:990:18: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
     virtual std::auto_ptr<stringVector_t> getProviderNames() = 0;
In file included from /usr/include/c++/6.3.1/memory:81:0,
                 from /usr/include/c++/6.3.1/tr1/memory:39,
                 from /opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/sharedPtr.h:68,
                 from /opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvType.h:41,
                 from /opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/requester.h:13,
                 from /opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/include/pv/pvaClient.h:17,
/usr/include/c++/6.3.1/bits/unique_ptr.h:49:28: note: declared here
   template<typename> class auto_ptr;
../examplePvaClientProcess.cpp: In function ‘void exampleProcess(const PvaClientPtr&)’:
../examplePvaClientProcess.cpp:28:10: note: candidate: operator<<(int, int) <built-in>
../examplePvaClientProcess.cpp:28:10: note:   no known conversion for argument 2 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘int’
In file included from /usr/include/c++/6.3.1/iostream:39:0,
                 from ../examplePvaClientProcess.cpp:12:
/usr/include/c++/6.3.1/ostream:108:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(std::basic_ostream<_CharT, _Traits>::__ostream_type& (*)(std::basic_ostream<_CharT, _Traits>::__ostream_type&)) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(__ostream_type& (*__pf)(__ostream_type&))
/usr/include/c++/6.3.1/ostream:108:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘std::basic_ostream<char>::__ostream_type& (*)(std::basic_ostream<char>::__ostream_type&) {aka std::basic_ostream<char>& (*)(std::basic_ostream<char>&)}’
/usr/include/c++/6.3.1/ostream:117:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(std::basic_ostream<_CharT, _Traits>::__ios_type& (*)(std::basic_ostream<_CharT, _Traits>::__ios_type&)) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>; std::basic_ostream<_CharT, _Traits>::__ios_type = std::basic_ios<char>]
       operator<<(__ios_type& (*__pf)(__ios_type&))
/usr/include/c++/6.3.1/ostream:117:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘std::basic_ostream<char>::__ios_type& (*)(std::basic_ostream<char>::__ios_type&) {aka std::basic_ios<char>& (*)(std::basic_ios<char>&)}’
/usr/include/c++/6.3.1/ostream:127:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(std::ios_base& (*)(std::ios_base&)) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(ios_base& (*__pf) (ios_base&))
/usr/include/c++/6.3.1/ostream:127:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘std::ios_base& (*)(std::ios_base&)’
/usr/include/c++/6.3.1/ostream:166:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(long int) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(long __n)
/usr/include/c++/6.3.1/ostream:166:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘long int’
/usr/include/c++/6.3.1/ostream:170:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(long unsigned int) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(unsigned long __n)
/usr/include/c++/6.3.1/ostream:170:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘long unsigned int’
/usr/include/c++/6.3.1/ostream:174:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(bool) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(bool __n)
/usr/include/c++/6.3.1/ostream:174:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘bool’
In file included from /usr/include/c++/6.3.1/ostream:638:0,
                 from /usr/include/c++/6.3.1/iostream:39,
/usr/include/c++/6.3.1/bits/ostream.tcc:91:5: note: candidate: std::basic_ostream<_CharT, _Traits>& std::basic_ostream<_CharT, _Traits>::operator<<(short int) [with _CharT = char; _Traits = std::char_traits<char>]
/usr/include/c++/6.3.1/bits/ostream.tcc:91:5: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘short int’
/usr/include/c++/6.3.1/ostream:181:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(short unsigned int) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(unsigned short __n)
/usr/include/c++/6.3.1/ostream:181:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘short unsigned int’
/usr/include/c++/6.3.1/bits/ostream.tcc:105:5: note: candidate: std::basic_ostream<_CharT, _Traits>& std::basic_ostream<_CharT, _Traits>::operator<<(int) [with _CharT = char; _Traits = std::char_traits<char>]
/usr/include/c++/6.3.1/bits/ostream.tcc:105:5: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘int’
/usr/include/c++/6.3.1/ostream:192:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(unsigned int) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(unsigned int __n)
/usr/include/c++/6.3.1/ostream:192:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘unsigned int’
/usr/include/c++/6.3.1/ostream:201:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(long long int) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(long long __n)
/usr/include/c++/6.3.1/ostream:201:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘long long int’
/usr/include/c++/6.3.1/ostream:205:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(long long unsigned int) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(unsigned long long __n)
/usr/include/c++/6.3.1/ostream:205:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘long long unsigned int’
/usr/include/c++/6.3.1/ostream:220:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(double) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(double __f)
/usr/include/c++/6.3.1/ostream:220:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘double’
/usr/include/c++/6.3.1/ostream:224:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(float) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(float __f)
/usr/include/c++/6.3.1/ostream:224:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘float’
/usr/include/c++/6.3.1/ostream:232:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(long double) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(long double __f)
/usr/include/c++/6.3.1/ostream:232:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘long double’
/usr/include/c++/6.3.1/ostream:245:7: note: candidate: std::basic_ostream<_CharT, _Traits>::__ostream_type& std::basic_ostream<_CharT, _Traits>::operator<<(const void*) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__ostream_type = std::basic_ostream<char>]
       operator<<(const void* __p)
/usr/include/c++/6.3.1/ostream:245:7: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const void*’
/usr/include/c++/6.3.1/bits/ostream.tcc:119:5: note: candidate: std::basic_ostream<_CharT, _Traits>& std::basic_ostream<_CharT, _Traits>::operator<<(std::basic_ostream<_CharT, _Traits>::__streambuf_type*) [with _CharT = char; _Traits = std::char_traits<char>; std::basic_ostream<_CharT, _Traits>::__streambuf_type = std::basic_streambuf<char>]
/usr/include/c++/6.3.1/bits/ostream.tcc:119:5: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘std::basic_ostream<char>::__streambuf_type* {aka std::basic_streambuf<char>*}’
In file included from /opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvData.h:26:0,
                 from /opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/include/pv/pvaClient.h:21,
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/sharedVector.h:868:15: note: candidate: template<class E> std::ostream& operator<<(std::ostream&, const epics::pvData::shared_vector<TO>&)
 std::ostream& operator<<(std::ostream& strm, const epics::pvData::shared_vector<E>& arr)
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/sharedVector.h:868:15: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:66: note:   ‘std::ostream {aka std::basic_ostream<char>}’ is not derived from ‘const epics::pvData::shared_vector<TO>’
In file included from /opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/include/pv/pvAccess.h:29:0,
                 from /opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/include/pv/pvaClient.h:27,
/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/include/pv/pvaVersion.h:114:30: note: candidate: std::ostream& epics::pvAccess::operator<<(std::ostream&, const epics::pvAccess::Version&)
 epicsShareFunc std::ostream& operator<<(std::ostream& o, const Version& v);
/opt/epics/EPICS-CPP-4.6.0/pvAccessCPP/include/pv/pvaVersion.h:114:30: note:   no known conversion for argument 2 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const epics::pvAccess::Version&’
In file included from /opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvCopy.h:19:0,
                 from /opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/include/pv/pvaClient.h:22,
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/bitSet.h:291:36: note: candidate: std::ostream& epics::pvData::operator<<(std::ostream&, const epics::pvData::BitSet&)
     epicsShareExtern std::ostream& operator<<(std::ostream& o, const BitSet& b);
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/bitSet.h:291:36: note:   no known conversion for argument 2 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const epics::pvData::BitSet&’
In file included from /opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/include/pv/pvaClient.h:21:0,
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvData.h:572:32: note: candidate: std::ostream& epics::pvData::operator<<(const epics::pvData::format::array_at_internal&, const epics::pvData::PVArray&)
 epicsShareExtern std::ostream& operator<<(format::array_at_internal const& manip, const PVArray& array);
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvData.h:572:32: note:   no known conversion for argument 1 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const epics::pvData::format::array_at_internal&’
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvData.h:267:32: note: candidate: std::ostream& epics::pvData::operator<<(std::ostream&, const epics::pvData::PVField&)
 epicsShareExtern std::ostream& operator<<(std::ostream& o, const PVField& f);
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvData.h:267:32: note:   no known conversion for argument 2 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const epics::pvData::PVField&’
In file included from /opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvData.h:24:0,
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvIntrospect.h:336:32: note: candidate: std::ostream& epics::pvData::operator<<(std::ostream&, const epics::pvData::Field&)
 epicsShareExtern std::ostream& operator<<(std::ostream& o, const Field& field);
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvIntrospect.h:336:32: note:   no known conversion for argument 2 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const epics::pvData::Field&’
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvIntrospect.h:283:32: note: candidate: std::ostream& epics::pvData::operator<<(std::ostream&, const epics::pvData::ScalarType&)
 epicsShareExtern std::ostream& operator<<(std::ostream& o, const ScalarType& scalarType);
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvIntrospect.h:283:32: note:   no known conversion for argument 2 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const epics::pvData::ScalarType&’
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvIntrospect.h:177:32: note: candidate: std::ostream& epics::pvData::operator<<(std::ostream&, const epics::pvData::Type&)
 epicsShareExtern std::ostream& operator<<(std::ostream& o, const Type& type);
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvIntrospect.h:177:32: note:   no known conversion for argument 2 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const epics::pvData::Type&’
In file included from /opt/epics/EPICS-CPP-4.6.0/pvaClientCPP/include/pv/pvaClient.h:18:0,
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/status.h:113:40: note: candidate: std::ostream& epics::pvData::operator<<(std::ostream&, const epics::pvData::Status::StatusType&)
         epicsShareExtern std::ostream& operator<<(std::ostream& o, const Status::StatusType& statusType);
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/status.h:113:40: note:   no known conversion for argument 2 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const epics::pvData::Status::StatusType&’
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/status.h:112:40: note: candidate: std::ostream& epics::pvData::operator<<(std::ostream&, const epics::pvData::Status&)
         epicsShareExtern std::ostream& operator<<(std::ostream& o, const Status& status);
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/status.h:112:40: note:   no known conversion for argument 2 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const epics::pvData::Status&’
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvData.h:1631:36: note: candidate: std::ostream& std::operator<<(std::ostream&, const epics::pvData::PVField*)
     epicsShareExtern std::ostream& operator<<(std::ostream& o, const epics::pvData::PVField *ptr);
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvData.h:1631:36: note:   no known conversion for argument 2 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const epics::pvData::PVField*’
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvIntrospect.h:1313:36: note: candidate: std::ostream& std::operator<<(std::ostream&, const epics::pvData::Field*)
     epicsShareExtern std::ostream& operator<<(std::ostream& o, const epics::pvData::Field *ptr);
/opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvIntrospect.h:1313:36: note:   no known conversion for argument 2 from ‘std::ostream {aka std::basic_ostream<char>}’ to ‘const epics::pvData::Field*’
In file included from /opt/epics/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvData.h:22:0,
/usr/include/c++/6.3.1/iomanip:363:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, std::_Put_time<_CharT>)
     operator<<(basic_ostream<_CharT, _Traits>& __os, _Put_time<_CharT> __f)
/usr/include/c++/6.3.1/iomanip:363:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:66: note:   ‘std::basic_ostream<char>’ is not derived from ‘std::_Put_time<_CharT>’
/usr/include/c++/6.3.1/iomanip:311:5: note: candidate: template<class _CharT, class _Traits, class _MoneyT> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, std::_Put_money<_MoneyT>)
     operator<<(basic_ostream<_CharT, _Traits>& __os, _Put_money<_MoneyT> __f)
/usr/include/c++/6.3.1/iomanip:311:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:66: note:   ‘std::basic_ostream<char>’ is not derived from ‘std::_Put_money<_MoneyT>’
/usr/include/c++/6.3.1/iomanip:238:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, std::_Setw)
     operator<<(basic_ostream<_CharT, _Traits>& __os, _Setw __f)
/usr/include/c++/6.3.1/iomanip:238:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘std::_Setw’
/usr/include/c++/6.3.1/iomanip:208:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, std::_Setprecision)
     operator<<(basic_ostream<_CharT, _Traits>& __os, _Setprecision __f)
/usr/include/c++/6.3.1/iomanip:208:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘std::_Setprecision’
/usr/include/c++/6.3.1/iomanip:178:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, std::_Setfill<_CharT>)
     operator<<(basic_ostream<_CharT, _Traits>& __os, _Setfill<_CharT> __f)
/usr/include/c++/6.3.1/iomanip:178:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:66: note:   ‘std::basic_ostream<char>’ is not derived from ‘std::_Setfill<_CharT>’
/usr/include/c++/6.3.1/iomanip:143:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, std::_Setbase)
     operator<<(basic_ostream<_CharT, _Traits>& __os, _Setbase __f)
/usr/include/c++/6.3.1/iomanip:143:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘std::_Setbase’
/usr/include/c++/6.3.1/iomanip:109:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, std::_Setiosflags)
     operator<<(basic_ostream<_CharT, _Traits>& __os, _Setiosflags __f)
/usr/include/c++/6.3.1/iomanip:109:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘std::_Setiosflags’
/usr/include/c++/6.3.1/iomanip:79:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, std::_Resetiosflags)
     operator<<(basic_ostream<_CharT, _Traits>& __os, _Resetiosflags __f)
/usr/include/c++/6.3.1/iomanip:79:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘std::_Resetiosflags’
In file included from /usr/include/c++/6.3.1/memory:82:0,
/usr/include/c++/6.3.1/bits/shared_ptr.h:66:5: note: candidate: template<class _Ch, class _Tr, class _Tp, __gnu_cxx::_Lock_policy _Lp> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, const std::__shared_ptr<_Tp, _Lp>&)
     operator<<(std::basic_ostream<_Ch, _Tr>& __os,
/usr/include/c++/6.3.1/bits/shared_ptr.h:66:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:66: note:   ‘std::ostream {aka std::basic_ostream<char>}’ is not derived from ‘const std::__shared_ptr<_Tp, _Lp>’
/usr/include/c++/6.3.1/ostream:628:5: note: candidate: std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&&, const _Tp&) [with _CharT = char; _Traits = std::char_traits<char>; _Tp = std::basic_ostream<char>] <near match>
     operator<<(basic_ostream<_CharT, _Traits>&& __os, const _Tp& __x)
/usr/include/c++/6.3.1/ostream:628:5: note:   conversion of argument 1 would be ill-formed:
/usr/include/c++/6.3.1/ostream:574:5: note: candidate: template<class _Traits> std::basic_ostream<char, _Traits>& std::operator<<(std::basic_ostream<char, _Traits>&, const unsigned char*)
     operator<<(basic_ostream<char, _Traits>& __out, const unsigned char* __s)
/usr/include/c++/6.3.1/ostream:574:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘const unsigned char*’
/usr/include/c++/6.3.1/ostream:569:5: note: candidate: template<class _Traits> std::basic_ostream<char, _Traits>& std::operator<<(std::basic_ostream<char, _Traits>&, const signed char*)
     operator<<(basic_ostream<char, _Traits>& __out, const signed char* __s)
/usr/include/c++/6.3.1/ostream:569:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘const signed char*’
/usr/include/c++/6.3.1/ostream:556:5: note: candidate: template<class _Traits> std::basic_ostream<char, _Traits>& std::operator<<(std::basic_ostream<char, _Traits>&, const char*)
     operator<<(basic_ostream<char, _Traits>& __out, const char* __s)
/usr/include/c++/6.3.1/ostream:556:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘const char*’
/usr/include/c++/6.3.1/bits/ostream.tcc:321:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, const char*)
     operator<<(basic_ostream<_CharT, _Traits>& __out, const char* __s)
/usr/include/c++/6.3.1/bits/ostream.tcc:321:5: note:   template argument deduction/substitution failed:
/usr/include/c++/6.3.1/ostream:539:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, const _CharT*)
     operator<<(basic_ostream<_CharT, _Traits>& __out, const _CharT* __s)
/usr/include/c++/6.3.1/ostream:539:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:66: note:   mismatched types ‘const _CharT*’ and ‘std::basic_ostream<char>’
/usr/include/c++/6.3.1/ostream:519:5: note: candidate: template<class _Traits> std::basic_ostream<char, _Traits>& std::operator<<(std::basic_ostream<char, _Traits>&, unsigned char)
     operator<<(basic_ostream<char, _Traits>& __out, unsigned char __c)
/usr/include/c++/6.3.1/ostream:519:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘unsigned char’
/usr/include/c++/6.3.1/ostream:514:5: note: candidate: template<class _Traits> std::basic_ostream<char, _Traits>& std::operator<<(std::basic_ostream<char, _Traits>&, signed char)
     operator<<(basic_ostream<char, _Traits>& __out, signed char __c)
/usr/include/c++/6.3.1/ostream:514:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘signed char’
/usr/include/c++/6.3.1/ostream:508:5: note: candidate: template<class _Traits> std::basic_ostream<char, _Traits>& std::operator<<(std::basic_ostream<char, _Traits>&, char)
     operator<<(basic_ostream<char, _Traits>& __out, char __c)
/usr/include/c++/6.3.1/ostream:508:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘char’
/usr/include/c++/6.3.1/ostream:502:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, char)
     operator<<(basic_ostream<_CharT, _Traits>& __out, char __c)
/usr/include/c++/6.3.1/ostream:502:5: note:   template argument deduction/substitution failed:
/usr/include/c++/6.3.1/ostream:497:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, _CharT)
     operator<<(basic_ostream<_CharT, _Traits>& __out, _CharT __c)
/usr/include/c++/6.3.1/ostream:497:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:66: note:   deduced conflicting types for parameter ‘_CharT’ (‘char’ and ‘std::basic_ostream<char>’)
In file included from /usr/include/c++/6.3.1/bits/ios_base.h:46:0,
                 from /usr/include/c++/6.3.1/ios:42,
                 from /usr/include/c++/6.3.1/ostream:38,
/usr/include/c++/6.3.1/system_error:209:5: note: candidate: template<class _CharT, class _Traits> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, const std::error_code&)
     operator<<(basic_ostream<_CharT, _Traits>& __os, const error_code& __e)
/usr/include/c++/6.3.1/system_error:209:5: note:   template argument deduction/substitution failed:
../examplePvaClientProcess.cpp:28:61: note:   cannot convert ‘epics::pvaClient::PvaClientGet::getData()().std::tr1::shared_ptr<epics::pvaClient::PvaClientGetData>::<anonymous>.std::tr1::__shared_ptr<_Tp, _Lp>::operator-><epics::pvaClient::PvaClientGetData, (__gnu_cxx::_Lock_policy)2u>()->epics::pvaClient::PvaClientGetData::showChanged(std::cout)’ (type ‘std::ostream {aka std::basic_ostream<char>}’) to type ‘const std::error_code&’
In file included from /usr/include/c++/6.3.1/string:52:0,
                 from /usr/include/c++/6.3.1/bits/locale_classes.h:40,
                 from /usr/include/c++/6.3.1/bits/ios_base.h:41,
/usr/include/c++/6.3.1/bits/basic_string.h:5340:5: note: candidate: template<class _CharT, class _Traits, class _Alloc> std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, const std::__cxx11::basic_string<_CharT, _Traits, _Alloc>&)
/usr/include/c++/6.3.1/bits/basic_string.h:5340:5: note:   template argument deduction/substitution failed:
Attachment: examplePvaClient.patch
Description: examplePvaClient.patch
Re: EPICS CPP 4.6.0 Build Error David Vine
Re: EPICS CPP 4.6.0 Build Error Andrew Johnson
Prev: EPICS CPP 4.6.0 Build Error David Vine
Next: Re: EPICS CPP 4.6.0 Build Error David Vine
