Subject: caRepeater: Syntax error: ")" unexpected
To: [email protected]
Date: Wed, 17 May 2017 17:29:25 +0300
Hi.
I've cross-built EPICS base for Raspberry Pi and then built pcaspy on Pi itself and now am trying to run some test apps.
Whenever I try to run caget.pl or caput.pl I get this:
main::(caget.pl:31):    eval { CA->pend_io($opt_w); };
  DB<3> /home/pi/epics/base-3.15.5/bin/linux-arm/caRepeater: 1: /home/pi/epics/base-3.15.5/bin/linux-arm/caRepeater: Syntax error: ")" unexpected
I've trying running both without specifying -w and with -w 10, the result is same.
I'm suspecting that something went wrong during cross-build and am currently looking for alternative ways to build EPICS base.
Meanwhile if you have any idea what this error means or how to properly diagnose it I'd appreciate any help.
Best regards,
Nick.
Prev: soft Timestamp fixed point support william.smith
Next: Re: caRepeater: Syntax error: ")" unexpected nb
Prev: Re: soft Timestamp fixed point support Andrew Johnson
