Subject: Re: EDM questions
To: [email protected]
Date: Sat, 20 May 2017 19:28:32 -0400
On 5/18/17 4:55 PM, Zelazny, Michael Stanley wrote:
Select the widget with left-mouse-click then middle-mouse-click and use Group and Ungroup.
From: [email protected] [[email protected]] on behalf of lzf neu [[email protected]]
Sent: Thursday, May 18, 2017 06:55
Subject: EDM questions
hi,
I have two questions to consult you:
1) I want to control a object ( a circle for example) visible or invisible by two PVs. Let me assume PVa and PVb :
if PVa=1 and PVb=1 then the visibility of the circle is invisible otherwise is visible.
I open the circle properties window and have no idea how to process two PV names in Visibility PV blank.
First off, I must point to the edm documentation for CALC\ and LOC\ variables.
https://ics-web.sns.ornl.gov/edm/eum.html#idp216560
To use logic to make a widget visible based on the values of two or more PVs, you will need to use a CALC _expression_ in the visibility PV field of the widget. The screenshot below uses two LOC\ PVs in the calculation, you can replace these with real PVs.
CALC\{A&&B}(LOC\PVa,LOC\PVb)  ---- -> If A is true and B is true then CALC is true.
2) how to control a text update widget visible or invisible according to PV.
however, there is no Visibility PV blank to fill in in Text update properties window.
As Zelazny replied earlier, you need to create a group for the widget you want to use visibility on. The group properties provide the attributes for visibility.
Cheers,
Tim
EDM questions lzf neu
RE: EDM questions Zelazny, Michael Stanley
Prev: Re: AreaDetector ImageJ viewer problem Mark Rivers
Next: Motor record: No longer issues a stop command when motor already stopped? James.OHea
Prev: RE: EDM questions Zelazny, Michael Stanley
Next: Troubleshooting the redirection-to-records feature of streamDevice Kevin Peterson
