Subject: Re: Siemens S7-300 PLC and EPICS
To: Florian Feldbauer <[email protected]>
Date: Tue, 23 May 2017 12:07:09 +0200 (CEST)
Hi Florian,
We had approximately the same project, controling pumps and gauges with EPICS via a S7-300.
My feedback. The best solution depends on which software you use to program your PLC, STEP7 or TIA PORTAL.
If you use TIA PORTAL, you can have compatibility problems with older S7-300 communication modules series (In addition legacy STEP7 software may be compulsory).
The solution we found was using s7nodave driver, which fits any TCP communication module, including that of the controller module itself, as well as any STEP7/TIA PORTAL version.
Best Regards
Remi FAURE
LPSC Grenoble
----- Mail original -----
De: "Florian Feldbauer" <[email protected]>
À: "EPICS Tech Talk" <[email protected]>
Envoyé: Mardi 23 Mai 2017 11:16:49
Objet: Siemens S7-300 PLC and EPICS
Hey all,
for the vacuum system of our tracking detector we want to use a PLC. We
decided to use a Siemens S7-300 which should control the pumps, gauges
and valves of our system.
The main question now is how to connect the PLC to our EPICS system?
I've seen that the CPU module has PROFINET or PROFIBUS DP interfaces. Is
there a device support available for those? Is there a better/easier
interface available maybe via an additional communication processor?
Any feedback appreciated!
Best regards,
Florian
| Dr. Florian Feldbauer                |
| Ruhr-Universität Bochum              |
| Experimentalphysik I AG              |
| Universitätsstr 150                  |
| D-44801 Bochum                       |
| Office: NB 2/134                     |
| Phone:  (+49)234 / 32-23563          |
Siemens S7-300 PLC and EPICS Florian Feldbauer
Prev: AW: Siemens S7-300 PLC and EPICS Rekow, Jens
Next: Re: Force TCP/IP reconnect from Asyn/Streamdevice Christoph Schroeder
Next: RE: Siemens S7-300 PLC and EPICS Mueller, Joachim
