Hello Mark,
with the line added to the database file the behavior is not much different,
just that I get now sometimes really multiple blocks per IOC task loop,
however with block IDs like this:
Block 1037
Block 1038
Block 1041
Block 1041
where e.g. a block with the 1041 data is sent twice. The ID number is
part of the blocks data.
A rough guess of me is that the copy to the ring buffer is late and the
source was already updated with the next block?
Is there a way to block execution in the IOC to be sure that the data is
in the Channel Access output buffer?
The HDF5 swmr is actually already implemented in the CA client. It is
not planned to use HDF5 writing as part of the IOC driver.
Best regards,
Michael
On 06.06.2017 20:28, Mark Rivers wrote:
> Hi Michael,
> By default the devAsynInt8Array callback does not buffer the array it receives, it copies it directly into the waveform record. If your driver callbacks are happening faster than the record processing and Channel Access transfer to the client then what you are seeing is expected.
> devAsynInt8Array can optionally use a ring-buffer to buffer the arrays passed to the callback function. This should eliminate the problem you are seeing. The ring buffer is disabled by default, but you can enable it by adding this line to your waveform record database file:
> info(asyn:FIFO, "20")
> where 20 is the maximum number of blocks you want to be able to buffer.
> This is documented here (search for "Buffering of Driver Callbacks"):
> http://www.aps.anl.gov/epics/modules/soft/asyn/R4-31/asynDriver.html
> How large is the data set you are trying to transfer? Are you breaking it into blocks because of its size, or is your source actually delivering it in sub-blocks?
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Michael Huth
> Sent: Tuesday, June 06, 2017 1:15 PM
> To: [email protected]
> Subject: Channel Access client sees only partial update.
> Hello,
> I'am quite new to Epics and ran into an issue where I could use a hint
> how to solve it:
> I have an IOC driver based on the area detector driver that should be
> extended for the transfer of a large data set from another source.
> So I setup a Record for it like this:
> record(waveform, "$(P)$(R)Data")
> field(PINI, "0")
> field(DTYP, "asynInt8ArrayIn")
> field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))DATA")
> field(FTVL, "CHAR")
> field(NELM, "$(SIZE_DATA_BLOCK)")
> field(SCAN, "I/O Intr")
> In the main thread of the IOC I split the large data set into smaller
> blocks and have a loop that calls
> doCallbacksInt8Array(blockPtr , block_size, Data, 0);
> for each block to transfer the blocks to the data base.
> In a second process a channel access client is subscribed with
> ca_create_subscription to 'DATA'.
> The issue is that the client receives only the last block from each loop
> of the IOC driver thread.
> I guess I have to wait somehow until the database processing has
> finished after each block?!?
> Best regards,
> Michael Huth
() byte physics
Dr. Michael Huth
Software-Developer
Company CEO: Thomas Braun
Address: Schwarzastraße 9, 12055 Berlin, Germany
Web: www.byte-physics.de
Telephone: +49 (0)30/52 68 23 22
Fax: +49 (0)30/52 68 43 26
USt-IdNr: DE276717536
- RE: Channel Access client sees only partial update. Mark Rivers
- Channel Access client sees only partial update. Michael Huth
<2017>
2025
<2017>
2025
