Hi Saeed,
I just tried what you did and it worked for me:
Windows 7 x64
Visual Studio 2015
ActiveState Perl 5.14.2
GNU Make 4.1
It works OK for me, the output is appended.
In your case the compiler is complaining that it cannot find xxxRecord.c. Does that file indeed exist in the src/ directory? This is your compile command that is failing:
cl -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32
-I../../../include -IC:/epics/base-3.15.5/include/compiler/msvc -IC:/epics/base-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include -c ../xxxRecord.c
This is mine that is working:
-I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include -c ../xxxRecord.c
They look identical to me.
However, after the cl command you get this output, presumably from make:
process_begin: CreateProcess(NULL, cl -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL
-DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../.
./../include/os/WIN32 -I../../../include -IC:/epics/base-3.15.5/include/compiler/msvc -IC:/epics/base-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include –c ../xxxRecord.c, ...) failed.
make (e=2): The system cannot find the file specified.
I am not sure what file it is complaining that it cannot fine. I don't see the "process_begin" message at all.
My complete output:
J:\epics\devel\example>H:\epics\base-3.15.5\bin\windows-x64-static\makebaseapp.pl -i -t example test
The following target architectures are available in base:
linux-x86_64
linux-x86
vxWorks-ppc32
windows-x64
linux-x86_64-gcc42
windows-x64-static
win32-x86-static
win32-x86
linux-x86-rhel6
windows-x64-static-vs2015
What architecture do you want to use? windows-x64
The following applications are available:
test
What application should the IOC(s) boot?
The default uses the IOC's name, even if not listed above.
Application name?
J:\epics\devel\example>make
make -C ./configure install
make[1]: Entering directory 'J:/epics/devel/example/configure'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
T_A=windows-x64 install
make[2]: Entering directory 'J:/epics/devel/example/configure/O.windows-x64'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/convertRelease.pl checkRelease
make[2]: Leaving directory 'J:/epics/devel/example/configure/O.windows-x64'
make[1]: Leaving directory 'J:/epics/devel/example/configure'
make -C ./testApp install
make[1]: Entering directory 'J:/epics/devel/example/testApp'
make -C ./src install
make[2]: Entering directory 'J:/epics/devel/example/testApp/src'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../..
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'J:/epics/devel/example/testApp/src/O.windows-x64'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../dbd -IH:/epics/base-3.15.5/dbd -o xxxRecord.h ../xxxRecord.dbd
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m initTrace.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../includ
e -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include initTrace.obj ../initTrace.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m testHello.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../includ
e -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include testHello.obj ../testHello.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m dbSubExample.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../inc
lude -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include dbSubExample.obj ../dbSubExample.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m devXxxSoft.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../inclu
de -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include devXxxSoft.obj ../devXxxSoft.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m xxxRecord.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../includ
e -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include xxxRecord.obj ../xxxRecord.c
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m testMain.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
-IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include testMain.obj ../testMain.cpp
"Creating dbd file test.dbd"
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -IH:/epics/base-3.15.5/dbd -o test.dbd base.dbd xxxSupport.dbd dbSubExample.dbd
testHello.dbd initTrace.dbd
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/registerRecordDeviceDriver.pl -I. -I.. -I../O.Common -I../../../dbd -IH:/epics/base-3.15.5/dbd -o test_registerRecordDeviceDrive
r.cpp ../O.Common/test.dbd test_registerRecordDeviceDriver J:/epics/devel/example
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m test_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/W
IN32 -I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include test_registerRecordDeviceDriver.o
bj test_registerRecordDeviceDriver.cpp
"Installing dbd file ../../../dbd/xxxSupport.dbd"
mkdir ../../../dbd
"Installing created dbd file ../../../dbd/test.dbd"
"Installing dbd file ../../../dbd/xxxRecord.dbd"
"Installing generated generic include file ../../../include/xxxRecord.h"
mkdir ../../../include
cl -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common
-I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -
xxxRecord.c
../xxxRecord.c(211): warning C4244: '=': conversion from 'epicsFloat64' to 'float', possible loss of data
IH:/epics/base-3.15.5/include -c ../devXxxSoft.c
devXxxSoft.c
IH:/epics/base-3.15.5/include -c ../dbSubExample.c
dbSubExample.c
IH:/epics/base-3.15.5/include -c ../testHello.c
testHello.c
IH:/epics/base-3.15.5/include -c ../initTrace.c
initTrace.c
link -nologo /subsystem:windows /dll -LTCG -incremental:no -opt:ref -release /MACHINE:X64 -out:testSupport.dll -implib:testSupport.lib xxxRecord.obj devXxxSoft.obj dbS
ubExample.obj testHello.obj initTrace.obj H:/epics/base-3.15.5/lib/windows-x64/dbRecStd.lib H:/epics/base-3.15.5/lib/windows-x64/dbCore.lib H:/epics/base-3.15.5/lib/windows-
x64/ca.lib H:/epics/base-3.15.5/lib/windows-x64/Com.lib
Creating library testSupport.lib and object testSupport.exp
Generating code
Finished generating code
"Installing shared library ../../../bin/windows-x64/testSupport.dll"
mkdir ../../../bin
mkdir ../../../bin/windows-x64
"Installing library ../../../lib/windows-x64/testSupport.lib"
mkdir ../../../lib
mkdir ../../../lib/windows-x64
cl -EHsc -GR -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -MD -DEPICS_BUILD_DLL -DEPICS_CA
LL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/b
ase-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include -c test_registerRecordDeviceDriver.cpp
ase-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include -c ../testMain.cpp
testMain.cpp
link -nologo -LTCG -incremental:no -opt:ref -release /MACHINE:X64 -out:test.exe test_registerRecordDeviceDriver.obj testMain.obj ../../../lib/windows-x64/t
estSupport.lib H:/epics/base-3.15.5/lib/windows-x64/dbRecStd.lib H:/epics/base-3.15.5/lib/windows-x64/dbCore.lib H:/epics/base-3.15.5/lib/windows-x64/ca.lib H:/epics/base-3.15.
Generating code
"Installing created executable ../../../bin/windows-x64/test.exe"
make[3]: Leaving directory 'J:/epics/devel/example/testApp/src/O.windows-x64'
make[2]: Leaving directory 'J:/epics/devel/example/testApp/src'
make -C ./Db install
make[2]: Entering directory 'J:/epics/devel/example/testApp/Db'
make[3]: Entering directory 'J:/epics/devel/example/testApp/Db/O.windows-x64'
"Installing ../../../db/dbExample1.db"
mkdir ../../../db
"Installing ../../../db/dbExample2.db"
"Installing ../../../db/dbSubExample.db"
"Installing substitution file ../../../db/user.substitutions"
make[3]: Leaving directory 'J:/epics/devel/example/testApp/Db/O.windows-x64'
make[2]: Leaving directory 'J:/epics/devel/example/testApp/Db'
make[1]: Leaving directory 'J:/epics/devel/example/testApp'
make -C ./iocBoot install
make[1]: Entering directory 'J:/epics/devel/example/iocBoot'
make -C ./ioctest install
make[2]: Entering directory 'J:/epics/devel/example/iocBoot/ioctest'
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/convertRelease.pl -t J:/epics/devel/example envPaths
perl -CSD H:/epics/base-3.15.5/bin/windows-x64/convertRelease.pl -a windows-x64 -t J:/epics/devel/example dllPath.bat
make[2]: Leaving directory 'J:/epics/devel/example/iocBoot/ioctest'
make[1]: Leaving directory 'J:/epics/devel/example/iocBoot'
On Behalf Of Saeed Haghtalab
Sent: Wednesday, June 07, 2017 4:11 PM
To: [email protected]
Subject: makeBaseApp.pl Compilation error on Windows x64
Hi all,
I'm trying to build a template application using makeBaseApp.pl on windows but It fails. The system is:
First I built EPICS base-3.15.5 on windows and it built successfully without error.
I create template application as well but when I want to build this, I see the following error:
C:\Users\Saeed3715\Desktop\myApp>makeBaseApp.pl -t example test
C:\Users\Saeed3715\Desktop\myApp>makeBaseApp.pl -i -t example test
Using target architecture windows-x64 (only one available)
C:\Users\Saeed3715\Desktop\myApp>make.exe
make.exe -C ./configure install
make.exe[1]: Entering directory 'C:/Users/Saeed3715/Desktop/myApp/configure'
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/makeMakefile.pl O.windows-x64 ../
make.exe -C O.windows-x64 -f ../Makefile TOP=../.. \
make.exe[2]: Entering directory 'C:/Users/Saeed3715/Desktop/myApp/configure/O.wi
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/convertRelease.pl checkRelease
make.exe[2]: Leaving directory 'C:/Users/Saeed3715/Desktop/myApp/configure/O.win
make.exe[1]: Leaving directory 'C:/Users/Saeed3715/Desktop/myApp/configure'
make.exe -C ./testApp install
make.exe[1]: Entering directory 'C:/Users/Saeed3715/Desktop/myApp/testApp'
make.exe -C ./src install
make.exe[2]: Entering directory 'C:/Users/Saeed3715/Desktop/myApp/testApp/src'
make.exe -C O.windows-x64 -f ../Makefile TOP=../../.. \
make.exe[3]: Entering directory 'C:/Users/Saeed3715/Desktop/myApp/testApp/src/O.
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/dbdToRecordtypeH.pl -I. -I.. -I
../O.Common -I../../../dbd -IC:/epics/base-3.15.5/dbd -o xxxRecord.h ../xxxRecor
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m initTrace.d -I. -I../
se-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include initTrace.obj .
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m testHello.d -I. -I../
se-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include testHello.obj .
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m dbSubExample.d -I. -I
/base-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include dbSubExample
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m devXxxSoft.d -I. -I..
ase-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include devXxxSoft.obj
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m xxxRecord.d -I. -I../
se-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include xxxRecord.obj .
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m testMain.d -I. -I../O
e-3.15.5/include/os/WIN32 -IC:/epics/base-3.15.5/include testMain.obj ../
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/dbdExpand.pl -I. -I.. -I../O.Co
mmon -I../../../dbd -IC:/epics/base-3.15.5/dbd -o test.dbd base.dbd xxxSupport.d
bd dbSubExample.dbd testHello.dbd initTrace.dbd
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/registerRecordDeviceDriver.pl -
I. -I.. -I../O.Common -I../../../dbd -IC:/epics/base-3.15.5/dbd -o test_regis
terRecordDeviceDriver.cpp ../O.Common/test.dbd test_registerRecordDeviceDriver C
perl -CSD C:/epics/base-3.15.5/bin/windows-x64/mkmf.pl -m test_registerRecordDe
./../../include/os/WIN32 -I../../../include -IC:/epics/base-3.15.5/include/compi
test_registerRecordDeviceDriver.obj test_registerRecordDeviceDriver.cpp
C:/epics/base-3.15.5/configure/RULES_BUILD:229: recipe for target 'xxxRecord.obj
make.exe[3]: *** [xxxRecord.obj] Error 2
make.exe[3]: Leaving directory 'C:/Users/Saeed3715/Desktop/myApp/testApp/src/O.w
C:/epics/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.window
make.exe[2]: *** [install.windows-x64] Error 2
make.exe[2]: Leaving directory 'C:/Users/Saeed3715/Desktop/myApp/testApp/src'
C:/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'src.install' fa
make.exe[1]: *** [src.install] Error 2
make.exe[1]: Leaving directory 'C:/Users/Saeed3715/Desktop/myApp/testApp'
C:/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'testApp.install
make.exe: *** [testApp.install] Error 2
does anyone know what is going on here?
