1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: IOC Severity Report
Cc: Talk EPICS Tech <[email protected]>
Date: Tue, 13 Jun 2017 11:30:04 -1000
Thanks all for the ideas. I had a few minutes during today's
telescope testing. I ran dbcar(0,1)  and see the first argument
should be the record name --at least in our version. So
dbcar(*,1) looks very useful here. We'll try again during
tomorrow's testing.
Back in the lab on a test system, I ran Andrew's suggestion:
> dbl "ai", "SEVR STAT"
gis1:CA_CLNT_CNT, "NO_ALARM", "NO_ALARM"
...snip...
gis1:tsrs:crword202:word, "INVALID", "UDF"
lis1:in:plcHb, "INVALID", "READ"
lis1:seq:word178, "INVALID", "UDF"
Then I checked some of these.
> dbpr lis1:seq:word178 10
ACKS: NO_ALARM      ACKT: YES           ADEL: 0             ALST: 0
AOFF: 0             ASG:                ASLO: 1             ASP: 0x0
BKPT: 00            DESC: analog input record               DISA: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DPVT: 0x634494
DSET: 0x1cd728      DTYP: AB DF1 serial EGU: volts          EGUF: 0
EGUL: 0             EOFF: 0             ESLO: 0             EVNT: 0
FLNK:DB_LINK lis1:seq:calc1word178.VAL  HHSV: NO_ALARM      HIGH: 0
HIHI: 0             HOPR: 0             HSV: NO_ALARM       HYST: 0
INIT: 1             INP:INST_IO @/dev/ttyS1 40 178          LALM: 0
LBRK: 0             LCNT: 0             LINR: NO CONVERSION LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW: 0              LSET: 0x63fef8
LSV: NO_ALARM       MDEL: 0
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00                   MLOK: 00 5a a6 80
MLST: 0             NAME: lis1:seq:word178                  NSEV: NO_ALARM
NSTA: NO_ALARM      ORAW: 0             PACT: 0             PBRK: 0x0
PHAS: 0             PINI: NO            PPN: 0x0            PPNR: 0x0
PREC: 0             PRIO: LOW           PROC: 0             PUTF: 0
RDES: 0x2d65d0      ROFF: 0             RPRO: 0             RSET: 0x1cde68
RVAL: 0             SCAN: I/O Intr      SDIS:CONSTANT 0.000000000000000e+00
SEVR: INVALID       SIML:DB_LINK lis1:simStatus NPP NMS     SIMM: NO
SIMS: NO_ALARM      SIOL:DB_LINK lis1:sim:word178 NPP NMS   SMOO: 0
SPVT: 0x66a590      STAT: UDF           SVAL: 0             TIME: <undefined>
TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 1
VAL: 0
This may be related to being in the lab. I'm not yet sure what's causing STAT: UDF.
And the follow one maybe because the PLC is no longer connected. At least it has
processed, looking at the TIME field.
> dbpr lis1:in:plcHb 10
ACKS: INVALID       ACKT: YES           ADEL: 0             ALST: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DPVT: 0x63446c
FLNK:CONSTANT 0     HHSV: NO_ALARM      HIGH: 0             HIHI: 0
HOPR: 0             HSV: NO_ALARM       HYST: 0             INIT: 0
INP:INST_IO @/dev/ttyS1 40 88           LALM: 0             LBRK: 0
LCNT: 0             LINR: NO CONVERSION LLSV: NO_ALARM      LOLO: 0
LOPR: 0             LOW: 0              LSET: 0x63fee8      LSV: NO_ALARM
MDEL: 0             MLIS: 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: 00 5a a6 60   MLST: 0             NAME: lis1:in:plcHb NSEV: NO_ALARM
PHAS: 0             PINI: YES           PPN: 0x0            PPNR: 0x0
SEVR: INVALID       SIML:CONSTANT 0.000000000000000e+00     SIMM: NO
SIMS: NO_ALARM      SIOL:CONSTANT 0.000000000000000e+00     SMOO: 0
SPVT: 0x66a498      STAT: READ          SVAL: 0
TIME: 2017-06-13 18:50:46.112607023     TPRO: 0             TSE: 0
TSEL:CONSTANT       UDF: 1              VAL: 0
Thanks again,
-Matt
On Tue, Jun 13, 2017 at 7:06 AM, Andrew Johnson <[email protected]> wrote:
While you can't do the filtering inside the IOC, if you don't mind using
an external tool to do that you can use the 'dbl' command to display all
your records (or all those of a specific record type) along with a
selection of their field values, so the command
will print the record name and SEVR and STAT field values for all ai
records in the IOC. Use "" or "*" to request all record types. I would
redirect the output of this command to a file and grep through that file
at my leisure:
  dbl "*", "SEVR STAT" > all-serv-stat.txt
I think this might even have worked with 3.13, but I'm not certain about
that (the "*" might not).
- Andrew
On 06/12/2017 03:46 PM, Matt Rippa wrote:
> We have some IOC's on 3.14.12.4 with several thousand records.
> Is there an easy way to get a severity report for any record where
> SEVR!=NO_ALARM ?
> I ask, because we're moving these systems from 3.13.x. We notice some
> non-existing input records now cause SEVR=INVALID and record processing
> is halted. This is a great new feature, btw.
> Thank you,
> -Matt
IOC Severity Report Matt Rippa
Re: IOC Severity Report Andrew Johnson
Prev: Re: saving samples Andrew Johnson
Next: the newest areaDetector 梁雅翔
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: IOC Severity Report Andrew Johnson
Next: crash in access security when other ioc reboots Dirk Zimoch
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
