Subject: archiver quickstart
To: tech-talk <[email protected]>
Date: Thu, 29 Jun 2017 17:24:18 +0800 (GMT+08:00)
Hi all,
    I try to use quickstart of archiver, because I know nothing about java.
    I did it as the web said "http://slacmshankar.github.io/epicsarchiver_docs/quickstart.html";.  But I got some error.
All I did.
I installed the mysql-connector-java-5.1.38.tar.gz and caj and jac.
mysql:
[lyx@localhost archiver]$ mysql --version
mysql  Ver 14.14 Distrib 5.7.17, for Linux (x86_64) using  EditLine wrapper
java:
java version "1.8.0_131"
Java(TM) SE Runtime Environment (build 1.8.0_131-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.131-b11, mixed mode)
The output of "./quickstart.sh apache-tomcat-9.0.0.M21.tar.gz":
[root@localhost archiver]# ./quickstart.sh apache-tomcat-9.0.0.M21.tar.gz
SRCDIR=/opt/archiver
DATADIR=/opt/archiver
Using org.epics.archiverappliance.config.persistence.InMemoryPersistence as the persistence layer
Found an older quickstart_tomcat folder. Stopping any existing instances.
Using CATALINA_BASE:   /opt/archiver/quickstart_tomcat/apache-tomcat-9.0.0.M21
Using CATALINA_HOME:   /opt/archiver/quickstart_tomcat/apache-tomcat-9.0.0.M21
Using CATALINA_TMPDIR: /opt/archiver/quickstart_tomcat/apache-tomcat-9.0.0.M21/temp
Using JRE_HOME:        /usr/java/jdk
Using CLASSPATH:       /opt/archiver/quickstart_tomcat/apache-tomcat-9.0.0.M21/bin/bootstrap.jar:/opt/archiver/quickstart_tomcat/apache-tomcat-9.0.0.M21/bin/tomcat-juli.jar
Jun 29, 2017 5:16:48 AM org.apache.catalina.startup.Catalina stopServer
SEVERE: Could not contact [localhost:[16000]]. Tomcat may not be running.
SEVERE: Catalina.stop:
java.net.ConnectException: Connection refused (Connection refused)
	at java.net.PlainSocketImpl.socketConnect(Native Method)
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
	at java.net.Socket.connect(Socket.java:589)
	at java.net.Socket.connect(Socket.java:538)
	at java.net.Socket.<init>(Socket.java:434)
	at java.net.Socket.<init>(Socket.java:211)
	at org.apache.catalina.startup.Catalina.stopServer(Catalina.java:477)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.apache.catalina.startup.Bootstrap.stopServer(Bootstrap.java:408)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:497)
Deleting an older quickstart_tomcat
total 4
drwxr-xr-x. 9 root root 4096 Jun 29 05:17 apache-tomcat-9.0.0.M21
Using 64 bit versions of libraries
Starting in the foreground...
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=128M; support was removed in 8.0
29-Jun-2017 05:17:19.878 SEVERE [main] org.apache.tomcat.util.digester.Digester.startElement Begin event threw exception
 java.lang.ClassNotFoundException: org.apache.catalina.core.JasperListener
	at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	at org.apache.tomcat.util.digester.ObjectCreateRule.begin(ObjectCreateRule.java:116)
	at org.apache.tomcat.util.digester.Digester.startElement(Digester.java:1201)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:509)
	at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(AbstractXMLDocumentParser.java:182)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1339)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2784)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:841)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:770)
	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
	at org.apache.tomcat.util.digester.Digester.parse(Digester.java:1469)
	at org.apache.catalina.startup.Catalina.load(Catalina.java:579)
	at org.apache.catalina.startup.Catalina.load(Catalina.java:630)
	at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:311)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:494)
29-Jun-2017 05:17:19.882 WARNING [main] org.apache.catalina.startup.Catalina.load Catalina.start using conf/server.xml: Error at (20, 67) : org.apache.catalina.core.JasperListener
29-Jun-2017 05:17:19.886 SEVERE [main] org.apache.tomcat.util.digester.Digester.startElement Begin event threw exception
	at org.apache.catalina.startup.Catalina.start(Catalina.java:644)
	at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:355)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:495)
29-Jun-2017 05:17:19.887 WARNING [main] org.apache.catalina.startup.Catalina.load Catalina.start using conf/server.xml: Error at (20, 67) : org.apache.catalina.core.JasperListener
29-Jun-2017 05:17:19.887 SEVERE [main] org.apache.catalina.startup.Catalina.start Cannot start server. Server instance is not configured.
And my file list:
[root@localhost archiver]# ls
Apache_2.0_License.txt
appliances.xml
archappl_v0.0.1_SNAPSHOT_22-June-2017T14-44-56.tar.gz
engine.war
etl.war
install_scripts
LICENSE
LTS
mgmt.war
MTS
mysql-community-release-fc20-5.noarch.rpm
NOTICE
quickstart.sh
quickstart_tomcat
RELEASE_NOTES
retrieval.war
sample_site_specific_content
Could you tell me how to do it?
(Fedora 23 64 )
Thank you,
Liang yx
Prev: RE: Area Detector and high performance NVME devices Mark S. Engbretson
Next: RE: Area Detector and high performance NVME devices ulrik.pedersen
Prev: RE: PVs disconnected in CSS BOY despite access through caget Iain Marcuson
Next: Re: archiver quickstart Shankar, Murali
