Subject: RE: CSS Text entry values not updating on PV change
To: Mark Rivers <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Wed, 5 Jul 2017 14:10:01 +0000
The driver is based on Stream Device, but I was able to update the records using OUT fields.  My problem turned out to be that I was setting a PV with name "GET", when I should have been setting a PV named "SET".  Once I did that, the values updated when I refreshed the OPI.
Thank you,
Iain.
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Wednesday, July 05, 2017 9:47 AM
> To: Iain Marcuson <[email protected]>; tech-
> [email protected] >> EPICS Tech Talk <[email protected]>
> Hi Iain,
> Is your driver based on asyn?
> If so, your setter records you can add the info tag asyn:READBACK.  This will
> force the setter (output) records to update their values based on a callback
> from the driver.  It is documented here:
> http://www.aps.anl.gov/epics/modules/soft/asyn/R4-
> 31/asynDriver.html#genericEpicsSupport
> Mark
> From: [email protected] [[email protected]] on
> behalf of Iain Marcuson [[email protected]]
> Sent: Wednesday, July 05, 2017 8:40 AM
> To: [email protected] >> EPICS Tech Talk
> Subject: CSS Text entry values not updating on PV change
> I am trying to update some text entry boxes with values from the IOC.  The
> controller ultimately sends and receives many parameters as a single block.  I
> have set up the IOC to have separate getters and setters that batch the
> values and transmit them.  I have text entry widgets for the setters and text
> update widgets for the getters.  What I would like to do on a Get operation is
> populate the setter widgets with the getter values.  I have tested this with
> caget and can see that the PV values are populated when I do a get, but the
> values in the CSS BOY GUI do not update.  Is there some way to populate the
> text entry widgets from the PV?
> Thank you,
> Iain.
CSS Text entry values not updating on PV change Iain Marcuson
RE: CSS Text entry values not updating on PV change Mark Rivers
Prev: RE: CSS Text entry values not updating on PV change Mark Rivers
Next: help - writing a table column from OPI BOY to PV Tomasz Brys
