Subject: RE: ioc crashing while using asyn & modbus
To: Eric Norum <[email protected]>, Gary Croke <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 12 Jul 2017 22:51:51 +0000
The code at line 252 is:
    status = pioPvt->pasynOctet->flush(pioPvt->octetPvt,pasynUser);
Since it appears to be getting the access violation at that line, and not in the flush() routine it suggests that something is wrong with one or more of the following pointers.
pioPvt
pioPvt->pasynOctet
pioPvt->octetPvt
pasynUser
You can probably examine these with gdb when it crashes.  If that does not work you can print their values on each call (using %p format) just before line 252 to see if one or more is NULL.
Before this crash occurred had there been device timeouts?
Sent: Wednesday, July 12, 2017 3:11 PM
To: Gary Croke
Cc: Mark Rivers
Subject: Re: ioc crashing while using asyn & modbus
What’s the code at line 252 doing?  I don’t have the source for asyn 4.31 handy to check.  Aysn 4.30 has a call to to the Octet flush method there.
Is there anything else at all in this IOC?  If so, could you strip it down as far as possible to ensure that it’s not some other code corrupting the stack or something like that.  I’ve got quite a few IOCs running the MODBUS code and haven’t seen any problems.
On Jul 12, 2017, at 1:00 PM, Gary Croke <[email protected]<mailto:[email protected]>> wrote:
Hi Mark,
Thanks for quick response.  Here's the output from gdb at the fault, and the output of the bt command:
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0xb1d45b70 (LWP 16755)]
0x001562d0 in writeRead (pasynUser=0x817839c, write_buffer=0x8178b04 "\004\003\f-", write_buffer_len=6, read_buffer=0x8178d5c "\003\070C\216ñÅC\217\221L", read_buffer_len=10, timeout=2,
   nbytesOut=0xb1d451bc, nbytesIn=0xb1d451b8, eomReason=0xb1d451b4) at ../../asyn/interfaces/asynOctetSyncIO.c:252
252     status = pioPvt->pasynOctet->flush(pioPvt->octetPvt,pasynUser);
Missing separate debuginfos, use: debuginfo-install glibc-2.12-1.192.el6.i686 libgcc-4.4.7-17.el6.i686 libstdc++-4.4.7-17.el6.i686 ncurses-libs-5.7-4.20090207.el6.i686 readline-6.0-4.el6.i686
(gdb) bt
#0  0x001562d0 in writeRead (pasynUser=0x817839c, write_buffer=0x8178b04 "\004\003\f-", write_buffer_len=6, read_buffer=0x8178d5c "\003\070C\216ñÅC\217\221L", read_buffer_len=10,
   timeout=2, nbytesOut=0xb1d451bc, nbytesIn=0xb1d451b8, eomReason=0xb1d451b4) at ../../asyn/interfaces/asynOctetSyncIO.c:252
#1  0x001ac3b0 in doModbusIO (pPlc=<value optimized out>, slave=10, function=3, start=3117, data=0x8176b78, len=4) at ../drvModbusAsyn.c:1730
#2  0x001ae6da in readPoller (pPlc=0x81789c0) at ../drvModbusAsyn.c:1322
#3  0x0030c7ea in start_routine (arg=0x817a340) at ../../../src/libCom/osi/os/posix/osdThread.c:385
#4  0x0032ebc9 in start_thread () from /lib/libpthread.so.0
#5  0x00491dee in clone () from /lib/libc.so.6
(gdb)
Eric Norum
ioc crashing while using asyn & modbus Gary Croke
Re: ioc crashing while using asyn & modbus Mark Rivers
Re: ioc crashing while using asyn & modbus Gary Croke
Prev: Re: How to compile only for a target architecture Andrew Johnson
Next: Re: ioc crashing while using asyn & modbus Mark Rivers
Prev: Re: ioc crashing while using asyn & modbus Gary Croke
Next: Re: ioc crashing while using asyn & modbus Torsten Bögershausen
