Subject: EPICS Qt release 3.5.1
To: "'[email protected]'" <[email protected]>
Date: Fri, 14 Jul 2017 02:02:20 +0000
Dear all,
We would like to announce the release of EPICS Qt release 3.5.1
This is available at https://github.com/qtepics with guidance notes
The main change in this release is that the QEPlugin library has been split the
into two distinct libraries which are:
  QEFramework - the functional library which contains the widgets themselves
                together with support functionality. qegui and any other bespoke
                display managers programs will need to link against this library.
  QEPlugin - strictly the widget plugin library, usable by any application using
             the ui loader, such as qegui and designer. The QEPlugin library is
             dependent on the QEFramework library.
Both libraries are part of the qeframework repository.
The release notes, located at https://qtepics.github.io/release_notes.html , go into
further detail.
Regards
Andrew C. Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
Prev: RE: NI4882 GPIB support for Linux 64bit? Mark Rivers
Next: Re: ioc crashing while using asyn & modbus Gary Croke
Prev: RE: NI4882 GPIB support for Linux 64bit? freddie.akeroyd
Next: clone R3.16 error Shen, Guobao
