Subject: RE: Linearly scale a PV
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 18 Jul 2017 11:35:56 +0000
This only works if the device support reads the value into RVAL and returns 0, rather than 2 (do not convert).  This means your value in watts would need to be an integer, because RVAL is a long.  So if your device support is reading a double directly into VAL and returning 2 then you cannot do the scaling in the ai record, you need to do it in an external calc record.
From: [email protected] [[email protected]] on behalf of Ralph Lange [[email protected]]
Sent: Tuesday, July 18, 2017 6:11 AM
To: EPICS Tech Talk
Subject: Re: Linearly scale a PV
Check
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Analog_Input#Read_and_Convert_Parameters
On Tue, Jul 18, 2017 at 12:47 PM, Abdalla Ahmad <[email protected]<mailto:[email protected]>> wrote:
Hi
Let's say we have a PV that reads a power in watts and needs to be displayed in kW. Is there fields that do this conversion without writing an external calc record for example?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265<tel:+962%205%20351%201348>
Fax: (+962-5) 3511423<tel:+962%205%20351%201423>
Mob: (+962-7)88183296<tel:+962%207%208818%203296>
www.sesame.org.jo<http://www.sesame.org.jo/>
Re: Linearly scale a PV Ralph Lange
Linearly scale a PV Abdalla Ahmad
Prev: Re: Linearly scale a PV Ralph Lange
Next: Re: Linearly scale a PV Ralph Lange
