Subject: Re: Creating an error counter
To: EPICS Tech Talk <[email protected]>
Date: Thu, 20 Jul 2017 22:02:05 +0200
It used to be that way some time ago.
In fact, the following minimal calc record does indeed count when being processed:
record(calc,"calc") {
  field(CALC,"VAL+1")
According to the release notes, the VAL keyword was added to the calc engine in Base 3.14.10, published nine years ago.
Cheers,
~Ralph
On Thu, Jul 20, 2017 at 8:52 PM, Southern, Tim <[email protected]> wrote:
To make the CALC record increment, you need to add the counter PV as an input for the CALC field to use. You can't use the VAL field itself as others have replied.  The following counter PV should solve your issue.
record(calc,$(P):$(R):DEBUG:COUNTER)  {
    field(DESC,"Counter of # of errors")
    field(SCAN,"Passive")
    field(INPA,"1")
    field(INPB, "$(P):$(R):DEBUG:COUNTER"
    field(CALC,"A+B")
-Tim
On 7/20/17 12:49 PM, Flewellen-Gore, Andrew (US) wrote:
Hello, and thanks for reading,
I’m having trouble keeping a counter for the number of errors coming in from an electron microscope (SEM). I’m using the Stream device driver to listen to incoming messages from the SEM, and when a message matches a certain format that identifies it as an error message, the PV processes and stores the new error message, overwriting the last. When this happens I would like to have a second record process and increment a counter, so that I can keep track of the number of error messages coming in.
My current setup gets the most recent error message correctly, but does not correctly increment the counter (the counter stays at zero). Here is the relevant code from the record definition file.
record(waveform,$(P):$(R):DEBUG:LISTEN)  {
    field(DESC,"Holds last SEM error")
    field(DTYP,"stream")
    field(NELM,"1000")
    field(FTVL,"CHAR")
    field(SCAN,"I/O Intr")
    field(FLNK,"$(P):$(R):DEBUG:COUNTER")
    field(INP, "@devhardware.proto debugListen() L5 0")
    field(INPA,"1")
    field(CALC,"VAL+A")
When the first record processes due to an interrupt on a received error message, it is supposed to forward-link the calc record to process, causing an increment to the counter.
Any help or insight is appreciated.
-Andrew
Creating an error counter Flewellen-Gore, Andrew (US)
Re: Creating an error counter Southern, Tim
Prev: Re: Creating an error counter Southern, Tim
Next: RE: Creating an error counter Flewellen-Gore, Andrew (US)
Next: Re: Creating an error counter Ford, Christopher
