Subject: Re: Archiver: Problems with disconnected PVs
To: Gabriel de Souza Fedel <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 5 Sep 2017 17:33:37 +0000
>> When I restart archiver "broken" PVs back to normally.
>> I will keep monitoring them
This is always a good idea. I have a script that uses the getCurrentlyDisconnectedPVs BPL and validates these on a path independent of whatever the archiver is using. That is, if the archiver goes thru a gateway, this monitoring script checks the liveness of the PV's directly on the VLAN.
Please let me know if you find any more details.
Murali
Sent: Monday, September 4, 2017 5:28 AM
To: Shankar, Murali; [email protected]
Cc: ([email protected])
When I restart archiver "broken" PVs back to normally. I will keep
monitoring them
Em 01-09-2017 16:43, Shankar, Murali escreveu:
> Also, which version is this? Apologies if you mentioned it before but I naturally assume you have a reasonably recent version.
Our version is Oct/2016
> Regards,
> Murali
Regards and Thank you again for help.
> From: Shankar, Murali
> Sent: Friday, September 1, 2017 12:23 PM
> To: Gabriel de Souza Fedel; [email protected]
>>> One thing look's strange, max_array_bytes.
> This would probably affect your waveforms mostly...
>>> and a few has problems (eventually disconnect).
> Are all these PV's from one or two IOCs? In this case I would look at the IOC.
>>>>> Your PV Details page for this PV could have information
> There should be lines here for "When did we request CA to make a connection to this PV?" and "Time elapsed since search request (s)". Does these look ok? Since you paused/resumed the PV; this should be the time you resumed the PV.
> The "Currently DisconnectedPV's" report also has some additional information; this is not always helpful but if all your live but disconnected PV's are in the same CAJ context ID then a restart may be required. Might be useful to get a stack trace of all the threads; there might be some clue here on where the search thread for that context is stuck.
>>> I take a look, but i can't see anything strange
> I think after this we get into wireshark territory (aka I'm out of ideas). You'll need to see if we are issuing search requests properly and getting proper responses etc.
> Regards,
> Murali
> From: Gabriel de Souza Fedel <[email protected]>
> Sent: Friday, September 1, 2017 11:59 AM
> Em 01-09-2017 15:10, Shankar, Murali escreveu:
>>>> is there another location
>> Depends on your setup of course but I see something like this in my arch.log right at the beginning.
>> <context class="com.cosylab.epics.caj.CAJContext">
>>   <preemptive_callback>true</preemptive_callback>
>>   <addr_list>gateway:5076 gateway:5077 gateway:5078 other-gateway:5064</addr_list>
>>   <auto_addr_list>false</auto_addr_list>
>>   <connection_timeout>30.0</connection_timeout>
>>   <beacon_period>15.0</beacon_period>
>>   <repeater_port>5069</repeater_port>
>>   <server_port>5076</server_port>
>>   <max_array_bytes>80000000</max_array_bytes>
>>   <event_dispatcher class="org.epics.archiverappliance.engine.epics.JCAEventDispatcherBasedOnPVName"/>
>> </context>
> I found it:
>    <addr_list></addr_list>
>    <auto_addr_list>true</auto_addr_list>
>    <beacon_period>30.0</beacon_period>
>    <repeater_port>5065</repeater_port>
>    <server_port>5064</server_port>
>    <max_array_bytes>30.0</max_array_bytes>
>    <event_dispatcher
> </context>
> One thing look's strange, max_array_bytes...Looks a bit low, can be the
> problem?
>>>> pause/resume I tried
>> Pausing/resuming tears down and recreates the CAJ channel for the PV so if you are unable to connect even after this you probably have some misconfiguration; that is, you can rule out most transient errors.
>>>> IOC's log on ioc machine right
>> Yes; sometimes there could be stuck tasks on the IOC side; you can check for that.
>> Your PV Details page for this PV could have information there that could help. You can get to this using something like so - http://localhost:17665/mgmt/bpl/getPVDetails?pv=Your_PV
>> Finally, would you be in a position to attempt a restart?
> I will try it, but on next week.
> The most strange thing is a lot of PV's work well, and a few has
> Thank you again
> Regards
>> Regards,
>> Murali
>> Sent: Friday, September 1, 2017 10:52 AM
>> Em 01-09-2017 13:39, Shankar, Murali escreveu:
>>>>> This seems like it might be a CA client configuration issue
>>> This is the most likely case. The engine prints out it's CAJ
>>> configuration on startup and you should be able to see this in your logs.
>> I didn't find it. I find engine/logs/catalina.err, is there another
>> location?
>>> You can try a couple of things. You can pause/resume the PV's in
>>> question and see if they reconnect back. You can also look in the IOC's
>>> logs and see if there is anything interesting going there.
>> pause/resume I tried. IOC's log on ioc machine right? apparently there
>> is no errors (on epics console).
>>> Regards,
>> Regards and thank you for the answer
>>> Murali
>> Gabriel Fedel
>> Software de Operação das Linhas de Luz
>> Laboratório Nacional de Luz Síncrotron – (LNLS)
>> Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
>> [email protected] | +55 (19) 3512 1226
>> www.lnls.cnpem.br
> Gabriel Fedel
> www.lnls.cnpem.br
Gabriel Fedel
www.lnls.cnpem.br
Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Re: Archiver: Problems with disconnected PVs Shankar, Murali
Prev: Re: C++ multi threaded application. Andrew Johnson
Next: Re: data refresh and add pv Shankar, Murali
Prev: Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Next: Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
