Subject: Re: Switched PDUs with EPICS support
To: [email protected]
Date: Thu, 7 Sep 2017 18:50:45 -0700
Hi All,
Thanks for all your responses.
We have found that we can use the APC PDUs with a standard cord length but now we face another challenge and that is that the B version of the desired PDU (like AP7900B [1]) has updated firmware .
Does anybody have EPICS support for this model/FW?
Žiga
[1] http://www.apc.com/shop/us/en/products/Rack-PDU-Switched-1U-15A-100-120V-8-5-15/P-AP7900B
On 10.5.2017 13:36, Bruce Hill wrote:
Hi Ziga,
We're using snmp to control PDU's from Leviton, iBootBar, and Sentry via EPICS.
Source code available here:
http://www.slac.stanford.edu/~bhill/epics-pcds/ioc-R3.14.12/common/Leviton/Leviton-R1.28.2.tar.gz
http://www.slac.stanford.edu/~bhill/epics-pcds/modules-R3.14.12/snmp/snmp-R1.1.0-2.7.0.tar.gz
Cheers,
- Bruce
On 05/10/2017 12:06 AM, [email protected] wrote:
few months ago I developed an EPICS IOC for ATEN PDU
(PE8208 - metered and switched) using SNMP device support
module (https://groups.nscl.msu.edu/controls/files/devSnmp.html);
source code available here:
    https://github.com/gtortone/ATEN-EPICS
Gennaro
On Tue, 9 May 2017, Žiga Oven wrote:
Hi All,
We are looking for alternative to APC switched PDUs as we would like to have cord longer than standard APC length of 12 feet. http://www.apc.com/shop/us/en/products/Rack-PDU-Switched-1U-15A-100-120V-8-5-15/P-AP7900B
I have checked the EPICS modules page and I have found several other options with existing support, but they all look a bit outdated (based on part numbers on the page and cross-referencing them with current vendor part numbers).
Are there other switched PDUs with EPICS support in use besides APC?
Žiga
Switched PDUs with EPICS support Žiga Oven
Re: Switched PDUs with EPICS support [email protected]
Re: Switched PDUs with EPICS support Bruce Hill
Prev: Re: C++ multi threaded application. Andrew Johnson
Next: data refresh and add pv 梁雅翔
Prev: Re: Switched PDUs with EPICS support Bruce Hill
Next: Release 0.7.0 of pvaPy Andrew Johnson
