1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: Cannot communicate with S7-400
Date: Tue, 12 Sep 2017 05:51:07 +0000
Dear Folks,
I’m trying to set up an Ethernet send/recv communcation between a S7 417-4 CPU with CP443-1 communication interface and
a simple EPICS IOC.
To create the S7 project I followed the instructions from this page http://epics.web.psi.ch/software/s7plc/ and also I use the device driver provided here.
My S7 project compiles and can be downloaded to the PLC and runs without any problem.
From the IOC side I did build the s7plc device driver and also configured it in the st.cmd script together with the substitution and template files.
After starting the IOC with softIoc st.cmd command, it’s being successfully initialized and is running, but then the communication timeout elapses and I get the following
error messages:
s7plcWaitForInput PLC1: select(5, 2.000000 sec) timed out
s7plcReceiveThread PLC1: read error after 0 of 4 bytes: Connection timed out
I’m sending a single float and also expecting another single float variable to recieve that’s why I set a length of 4 bytes.
Also when I ping the PLC from the EPICS VM’s terminal I got responses without any loss so the communication should be fine between the systems.
I guess I’m missing some settings or maybe I’m completely doing it wrong as I’m kinda new to EPICS so any help would be appreciated!
I can also send the S7 project and the EPICS IOC files for further troubleshooting if required!
Thank you all!
Yours truly,
____________________
Szabolcs Antal
Software Developer
cid:companylogo
evopro systems engineering Kft.
member of the evopro group
HU-4031, Debrecen, Köntösgátsor 1-3. Daniella Ipari Park
www.evopro-group.com
Mobile: +36 30 310 0367
Ez az e-mail (ideértve annak bármely mellékletét) bizalmas információkat tartalmaz és jogi védelem alatt áll. Az üzenet kizárólag a címzett(ek)nek szól. Amennyiben Ön nem a küldemény címzettje, úgy a téves kézbesítést kérjük haladéktalanul jelezze e-mailben a feladónak és a teljes küldeményt helyreállíthatatlanul törölje. Amennyiben Ön nem az üzenet címzettje, kérjük ne készítsen másolatot az üzenetről, ne továbbítsa, ne tárja fel és ne tegye hozzáférhetővé azt más személy(ek) számára, továbbá semmilyen célra ne használja fel a bizalmas információt: ezen magatartások bármelyike a levéltitok megsértésének minősül.
Information in this e-mail (including any attachment hereto) is confidential and may be legally privileged. It is intended solely for the attention of the addressee(s). If you received this message in error, please immediately notify the sender by return e-mail and irrecoverably delete the whole message. If you received this e-mail in error, please do not copy it, do not forward, disclose or make it available to other person(s), and do not use the confidential information for any purpose: any such action is regarded as a breach of confidence.
RE: Cannot communicate with S7-400 Antal, Szabolcs
Prev: Re: data refresh and add pv Shen, Guobao
Next: releasing support for Beckhoff KL2541 motor driver Davide Marcato
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Automatic refresh of OPI Andrew Johnson
Next: RE: Cannot communicate with S7-400 Antal, Szabolcs
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
