Subject: PointGrey Firmware
To: Mark Rivers <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 20 Sep 2017 15:25:22 +0000 (UTC)
Mark - Question
Historically you have mentioned in Tech-Talk that PointGrey only tends to post the latest firmware on their website once *all* the cameras in a specific model class are know to work. So asking support for the latest versions is suggested, since the posted firmware may be very old and buggy.
I did that recently and asked what the firmware was for 3 grasshopper modules and support responded with
I have attached a dropbox link below for your new firmware. This is compatible
with all GS3-U3 cameras.
gs3-u3-2.31.3-00.ez2
However, even the PointGrey website says that
Grasshopper3 USB3 Firmware
This is the latest version of firmware for the Grasshopper3 USB3 cameras. Note that the firmware is model specific.
Should I assume that Support is correct and that this is indeed a one size fits all firmware package, or at least contains multiple firmware images that will install as required, or is a single image most probably not to work at all. If not, does the camera flashing software have enough intelligence not to update an incorrect firmware? Or be able to restore a legacy firmware if the process fails? I do not have a camera in hand to test and wanted an expert opinion before I walk over to a beam line and start flashing hardware.
RE: PointGrey Firmware Mark Rivers
Prev: Re: Ideas / Suggestions for the future of VME-CPU Operating Systems Heinz Junkes
Next: Re: Ideas / Suggestions for the future of VME-CPU Operating Ambrosch Kristian (PSI)
Prev: Re: Ideas / Suggestions for the future of VME-CPU Operating Systems Goetz Pfeiffer
Next: RE: PointGrey Firmware Mark Rivers
