Subject: Re: dbVerify removed from EPICS 3.16
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Thu, 21 Sep 2017 10:14:43 -0500
On 09/21/2017 01:23 AM, [email protected] wrote:
> From: Andrew Johnson [mailto:[email protected]]
>> I don't see any particular reason why we couldn't restore the routine
>> (with additions to support 64-bit integer field types
> Please, I'd be very grateful.
I will see what I can do, unless Michael D has objections.
>> — I assume you
>> have already discovered that the values of DBF_FLOAT and above changed
>> in 3.16 to insert DBF_INT64 and DBF_UINT64).
> Aha!  Thanks for the pointer.  I haven't got that far with 3.15 support.
> I know that my pythonIoc now segmentation faults under 3.15, but hadn't
> got as far as figuring out why or where (somebody else was using it, for
> them it was enough to revert to 3.14).  Maybe this will be a clue.
Actually no, it's only 3.16.1 and above that has those new type codes.
However given the other changes that happened between 3.14 and 3.15 I'm
not too surprised that you would have to make changes. All of the
significant alterations should have been described in the Release Notes.
- Andrew
>> Michael D, would you have any objections to that happening?
Re: dbVerify removed from EPICS 3.16 Michael Davidsaver
dbVerify removed from EPICS 3.16 michael.abbott
Re: dbVerify removed from EPICS 3.16 Andrew Johnson
RE: dbVerify removed from EPICS 3.16 michael.abbott
Prev: new Scaler driver 梁雅翔
Next: Re: dbVerify removed from EPICS 3.16 Michael Davidsaver
Prev: RE: dbVerify removed from EPICS 3.16 michael.abbott
