Subject: Enumerated Strings in CSS BOY
To: EPICS Tech Talk <[email protected]>
Date: Thu, 21 Sep 2017 17:45:30 +0000
My software queries a status value from a sensor.  I want to display the status as a string in my OPI.  The status values are neither sequential nor zero-indexed.  I tried to create an mbbi record with the *VL and *ST fields set to match the status string with the status value.  CSS BOY, however, does not display the string matching the mbbi VAL number, but the *ST field corresponding to the VAL number.  For example:
Field(ONVL, 129)
Field(ONST,"Done")
Field(THVL,1)
Field(THST,"Clearing")
If the mbbi VAL field is 1, then CSS BOY will display "Done" as opposed to "Clearing".
What is the preferred way of outputting a string with such an enum?
Thank you,
Iain.
Re: Enumerated Strings in CSS BOY Andrew Johnson
Prev: Re: APS Firewall Ralph Lange
Next: Re: Enumerated Strings in CSS BOY Andrew Johnson
