Subject: AD: save array of floats into HDF5 as attribute
Date: Tue, 26 Sep 2017 10:44:52 +0200
can I save an array of floats into HDF5 file through areaDetector Attribute?
XML definition:
<Attribute name="GaussParams"         type="EPICS_PV" source="DTU:GaussParams"                dbrtype="DBR_NATIVE"  description="Gauss params"/>
where PV is:
record(waveform, "$(P)$(R)GaussParams")
field(FTVL, "DOUBLE")
field(NELM, "10")
With the above, I only a single (first) value saved in the HDF5 file as opposed to all 10.
Hinko
.. the more I see the less I believe.., AE AoR
Prev: RE: Coordinated motion with EPICS motor record Mark Rivers
Next: RE: save array of floats into HDF5 as attribute Mark Rivers
Prev: RE: Coordinated motion with EPICS motor record So, Sung-Leung
