1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: registerRecordDeviceDriver.pl takes a long time to finish
Date: Wed, 27 Sep 2017 12:15:05 +0200
Under 3.15.4 perl script execution takes a lot of time on Linux Mint, while it executes in a jiffy on CentOS.
I added a time in front of the perl call in RULES.db:
time perl -CSD /devel/root/R3.15.4/base/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I/devel/root/R3.15.4/modules/adcore-master/dbd -I/devel/root/R3.15.4/modules/adsimdetector-master/dbd -I/devel/root/R3.15.4/modules/asyn-master/dbd -I/devel/root/R3.15.4/modules/autosave-master/dbd -I/devel/root/R3.15.4/modules/busy-master/dbd -I/devel/root/R3.15.4/modules/calc-master/dbd -I/devel/root/R3.15.4/modules/sscan-master/dbd -I/devel/root/R3.15.4/base/dbd    -o simDetectorApp_registerRecordDeviceDriver.cpp ../O.Common/simDetectorApp.dbd simDetectorApp_registerRecordDeviceDriver /devel/stage/R3.15.4/iocs/simdetectorioc-master
29.95user 0.02system 0:29.98elapsed 99%CPU (0avgtext+0avgdata 19256maxresident)k
I think other calls to perl are awfully slow, too..
Any idea why it might be so slow?
Hinko
.. the more I see the less I believe.., AE AoR
Re: registerRecordDeviceDriver.pl takes a long time to finish Johnson, Andrew N.
Re: registerRecordDeviceDriver.pl takes a long time to finish Luca Cavalli
Prev: Re: Question about epics/Labview and Ca Lab -- how to put time to my PV from signal waveform chart in labview. Carsten Winkler
Next: Re: registerRecordDeviceDriver.pl takes a long time to finish Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: issue with epics in python Matt Newville
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
