Subject: Re: Motor module problem
To: Jörn Dreyer <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 28 Sep 2017 11:05:50 +0200
First of all, I don't understand that either.
Which versions (EPICS base, motor) do you use ?
Are you sure that everything is freshly compiled ?
And, could you send us a complete log file ?
On 28/09/17 10:04, Jörn Dreyer wrote:
Hello,
currently I'm working on a piezo motor driver based on the
asynMotorController. At startup of the IOC the Axis::move command is called
with parameters that I do not understand. If I put a printout statement at the
beginning of the function like this:
printf("%s %d %s %f %d %f %f %f\n", "Moving axis", axisNo_+1, "to position",
position, relative, minVelocity, maxVelocity, acceleration);
it results in:
Moving axis 1 to position inf 0 0.000000 0.000000 0.000000
The corresponding record looks like this:
record(motor, "A:m1") {
   field(DESC, "Mirror 1")
   field(DTYP, "asynMotor")
   field(DIR, "1")
   field(VELO, "110.")
   field(VBAS, ".05")
   field(ACCL, ".5")
   field(BDST, "0")
   field(BVEL, "1.0")
   field(BACC, "2")
   field(OUT, "@asyn(B,0)")
   field(MRES, "0.00001")
   field(PREC, "5")
   field(EGU, "mm")
   field(DHLM, "0.32768")
   field(DLLM, "1")
   field(INIT, "")
   field(RTRY, "5")
   field(TWV, "1")
   field(SDIS, "A:m1_able.VAL")
   field(VMAX, "190.")
It gets called three times, first with inf, then with DHLM, and then with
10000. Looks like it wants to do something like homing. How can I prevent
this?
Jörn
Re: Motor module problem Jörn Dreyer
Prev: Motor module problem Jörn Dreyer
Next: Re: Motor module problem Jörn Dreyer
