Subject: Re: init function in device support
To: "Thomas, Patrick" <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Fri, 6 Oct 2017 10:53:13 +0200
On 10/06/2017 02:04 AM, Thomas, Patrick wrote:
> Hi,
> I am trying to understand how to use the 'long init(int after)' function
> in device support. Is it expected that I define a separate such function
> for each record type (there is a pointer to it in the dset for each
> record type)? I would like to define a single function that gets called
> after all records of *all types* have been initialized. Is this
> possible? If so, is there an example available?
The device support init() function isn't required, and may be omitted.
IMO it's not very useful.  I've never had record type/DTYP specific
initialization.
What you want is best accomplished with an init hook (see initHooks.h).
My usual starting point is to call initHookRegister() from a registrar
function, then use the initHookAfterIocRunning event to start eg. driver
specific worker threads.  This happens near the end of iocInit().
Re: init function in device support Thomas, Patrick
Prev: Re: init function in device support Johnson, Andrew N.
Next: aD driver for Mako G G-032? Ralph Lange
Next: Re: init function in device support Thomas, Patrick
