1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Writing PVs from an amalgamated structure
To: Iain Marcuson <[email protected]>
Date: Mon, 9 Oct 2017 13:49:55 +0000
Hey Iain -
I would do this in the sequencer (SNL - State Notation Language). The sequencer will do all the connection handling to the PVs and you can include your own library (C/C++) for the file operations.  I think you'll find it a nice environment to work in on the IOC.
   Ned
From: [email protected] <[email protected]> on behalf of Iain Marcuson <[email protected]>
Sent: Monday, October 9, 2017 08:23 AM
To: Johnson, Andrew N.
Cc: EPICS Tech Talk
Subject: RE: Writing PVs from an amalgamated structure
I have attached a diagram of what we are planning at the moment.  The functions ReadConfigFile() and WriteConfigFile() would be called when the user requests a load or save.  The configuration data would be stored in one big structure.  GetData() returns a pointer to the structure, and is intended as the link between the PVs and the library.
> -----Original Message-----
> From: Johnson, Andrew N. [mailto:[email protected]]
> Sent: Saturday, October 07, 2017 6:59 AM
> Cc: EPICS Tech Talk <[email protected]>
> Hi Iian,
> I think we need to know quite a bit more about what you're trying to do, and
> where/when these configuration files will be read and/or written. The
> answers are likely to be very different depending on what you tell us, and I
> don't think anyone wants to spend time answering the wrong question.
> - Andrew
> Sent from my iPad
> > On Oct 6, 2017, at 6:22 PM, Iain Marcuson
> <[email protected]> wrote:
> > I need to create support for reading and writing a configuration file, but I
> also have to support non-EPICS environments.  I am thus considering making
> a library to be used in the IOC.  My present idea is to pass EPICS a pointer to a
> structure containing all the configuration options.  However, I do not know
> what best practices are for mapping PVs to the memory location.  What are
> the accepted methods?
> > Thank you,
> > Iain.
Re: Writing PVs from an amalgamated structure Ralph Lange
Writing PVs from an amalgamated structure Iain Marcuson
Re: Writing PVs from an amalgamated structure Johnson, Andrew N.
RE: Writing PVs from an amalgamated structure Iain Marcuson
Prev: RE: Writing PVs from an amalgamated structure Iain Marcuson
Next: Re: Writing PVs from an amalgamated structure Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
