Subject: Re: EPICS areadetecto and EPICSV4
To: Mark Rivers <[email protected]>, "Gofron, Kazimierz" <[email protected]>, "'[email protected]'" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Thu, 12 Oct 2017 11:15:19 +0200
On 10/12/2017 09:40 AM, Mark Rivers wrote:
> Hi Kaz,
> I think you are referring to a different problem that occurs with more recent unreleased versions of the V4 code after pvAccess was split into 3 libraries.
The next release of the pvAccessCPP module injects a make variable*
$(EPICS_BASE_PVA_CORE_LIBS) meant to be used with the long existing
$(EPICS_BASE_IOC_LIBS).
eg. in the pva2pva module
> softIocPVA_LIBS += qsrv
> softIocPVA_LIBS += $(EPICS_BASE_PVA_CORE_LIBS)
> softIocPVA_LIBS += $(EPICS_BASE_IOC_LIBS)
At present this variable is defined as:
> EPICS_BASE_PVA_CORE_LIBS = pvAccessIOC pvAccessCA pvAccess pvData
For those following Git master, updating to the latest will make this
variable available.  Verify by looking for 'cfg/CONFIG_PVA_CORE' after
running 'make'.
* At least for versions of Base which support this.  For 3.14 series
this is >= 3.14.12.5, and for 3.15 series this is >= 3.15.2.  It may
work back as far as 3.14.10, but I haven't tested.
RE: EPICS areadetecto and EPICSV4 Gofron, Kazimierz
RE: EPICS areadetecto and EPICSV4 Mark Rivers
Prev: RE: EPICS areadetecto and EPICSV4 Mark Rivers
Next: EPICS training information Mohamed Chaouechi
Next: Re: Automatic flat db generation Luca Cavalli
