Subject: Re: Problems with motor record
To: [email protected]
Date: Tue, 17 Oct 2017 12:29:23 +0200
Hi Torsten
I enabled the full debugging output from my motor driver, and this is what I
get:
Starting iocInit
## EPICS R3.15.5
## EPICS Base built Feb  6 2017
2017/10/17 12:25:24.277 port1 0 registerInterruptUser
2017/10/17 12:25:24.277 asynMotorController:readGenericPointer: MotorStatus =
status0, position=1.000000, encoder position=1.000000, velocity=0.000000
2017/10/17 12:25:24.277 devMotorAsyn::build_trans: P:m1 motor_cmnd=9, pact=0,
value=0.000010
2017/10/17 12:25:24.277 devAsynMotor::build_trans: calling queueRequest,
pmsg=0xcae280, sizeof(*pmsg)=24pmsg->command=10, pmsg->interface=1, pmsg-
>dvalue=0.000010
2017/10/17 12:25:24.277 port1 addr 0 queueRequest priority 0 not lockHolder
2017/10/17 12:25:24.277 devMotorAsyn::init_controller, P:m1 setting of
position not required, position=1.000000, mres=0.000010, dval=0.000000,
rdbd=0.0000102017/10/17 12:25:24.277 P:m1 devMotorAsyn::update_values,
needUpdate=1
2017/10/17 12:25:24.278 devMotorAsyn::build_trans: P:m1 motor_cmnd=19, pact=0,
value=0.000000
2017/10/17 12:25:24.278 devAsynMotor::build_trans: calling queueRequest,
pmsg=0xcbc770, sizeof(*pmsg)=24pmsg->command=14, pmsg->interface=1, pmsg-
>dvalue=0.000000
2017/10/17 12:25:24.278 port1 addr 0 queueRequest priority 0 not lockHolder
2017/10/17 12:25:24.278 devMotorAsyn::build_trans: P:m1 motor_cmnd=20, pact=0,
value=0.000000
pmsg=0xcbc6a0, sizeof(*pmsg)=24pmsg->command=15, pmsg->interface=1, pmsg-
>dvalue=0.000000
2017/10/17 12:25:24.278 port1 0 autoConnect
2017/10/17 12:25:24.278 asynPortDriver:connect:, pasynUser=0xca79a8
2017/10/17 12:25:24.278 asynManager::portThread port=port1 callback
2017/10/17 12:25:24.278 devMotorAsyn::asynCallback: P:m1 pmsg=0xcae280,
sizeof(*pmsg)=24, pmsg->command=10,pmsg->interface=1, pmsg->ivalue=0, pmsg-
>dvalue=0.000010, pasynUser->reason=13
2017/10/17 12:25:24.278 asynPortDriver:getDoubleParam: port=port1 error
getting parameter 6 MOTOR_VEL_BASE, in list 0, value undefined
getting parameter 7 MOTOR_ACCEL, in list 0, value undefined
2017/10/17 12:25:24.278 asynMotorController:writeFloat64: Set driver port1,
axis 0 encoder ratio=0.000010
2017/10/17 12:25:24.278 asynMotorController:writeFloat64:: axis=0,
function=13, value=0.000010
2017/10/17 12:25:24.278 devMotorAsyn::asynCallback: P:m1 pmsg=0xcbc770,
sizeof(*pmsg)=24, pmsg->command=14,pmsg->interface=1, pmsg->ivalue=0, pmsg-
>dvalue=0.000000, pasynUser->reason=17
axis 0 high limit=0.000000
function=17, value=0.000000
2017/10/17 12:25:24.278 devMotorAsyn::asynCallback: P:m1 pmsg=0xcbc6a0,
sizeof(*pmsg)=24, pmsg->command=15,pmsg->interface=1, pmsg->ivalue=0, pmsg-
>dvalue=0.000000, pasynUser->reason=19
2017/10/17 12:25:24.278 asynPortDriver:setDoubleParam: port=port1 error
setting parameter 19 in list 0, wrong type
2017/10/17 12:25:24.278 asynMotorController:writeFloat64 error, status=8
axis=0, function=19, value=0.000000
2017/10/17 12:25:24.278 devMotorAsyn::asynCallback: P:m1 pasyn{Float64,Int32}-
>write returned
I have checked, that the code is completely compiled an linked with thze
correct versions of asyn (4.32) and motor (R6-9).
Jörn
Am Dienstag, 17. Oktober 2017, 11:21:00 CEST schrieb Torsten Bögershausen:
> The last problem reports smelled as if the code executed was not
> corresponding to the source code. (things not compiled/linked
> appropriately)
> This one looks the same.
> Can you put your source code somewhere ?
> On 17/10/17 11:07, Jörn Dreyer wrote:
> > Hi,
> > still fighting with the motor record...
> > I get a strange error message at startup of my IOC:
> > asynPortDriver:setDoubleParam: port=port1 error setting parameter 19 in
> > list 0, wrong type
> > asynMotorController:writeFloat64 error, status=8 axis=0, function=19,
> > value=0.000000
> > devMotorAsyn::asynCallback: m1 pasyn{Float64,Int32}->write returned <empty
> > error message>
> > In my parameter list the number 19 is motorClosedLoop, which indeed is an
> > int32 parameter. I'm using basic_asyn_motor.db to setup the motor record.
> > What goes wrong here?
> > Regards
> > Jörn
Dr. Joern Dreyer
HIBEF DAQ + Controls
Institut für Strahlenphysik
Helmholtz-Zentrum Dresden - Rossendorf e.V
Abt. FWKH                Tel: +49 351 260 3263
                                   FAX: +49 351 260 3700
01314 Dresden        eMail: [email protected]
Bautzner Landstraße 400, 01328 Dresden
Vorstand: Prof. Dr. Roland Sauerbrey, Dr. Dr. h. c. Peter Joehnk
VR 1693 beim Amtsgericht Dresden
Problems with motor record Jörn Dreyer
Re: Problems with motor record Torsten Bögershausen
Prev: Re: Problems with motor record Torsten Bögershausen
Next: RE: Problems with motor record Mark Rivers
