I have menus with 16 items, and I haven't seen this problem. I'm running 3.1.11. I don't have ready access to 3.1.9, but I can run with 3.1.7, and it also doesn't show the problem. I'm running Redhat 6.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov) Advanced Photon Source, Argonne National Lab From: [email protected] <[email protected]> on behalf of Gerrit Kühn <[email protected]>
Sent: Wednesday, October 25, 2017 9:55:18 AM To: [email protected] Subject: medm sigsev on related display Hello,
I found some issue here using medm 3.1.9: I'd like to use a "related display" with visual "a column of buttons". This works fine up to 14 labels. With adding the 15th label, I get a sigsev terminating medm. 15 items work fine using the "menu" visual, just the column of buttons appears to cause the issue. It also happens when starting off with a new screen, just containing this single related display. Can anyone reproduce this? Is this a bug (if so, where should I file it?), or am I doing something wrong? cu Gerrit
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
