On 10/26/2017 11:42 AM, Rod Nussbaumer wrote:
> Your pattern for using find doesn't match the file you're trying to
> find; observe case sensitivity with respect to the 'I' in iocxxInclude.dbd
From man find:
> -iname pattern
> Like -name, but the match is case insensitive. For example, the
> patterns `fo*' and `F??' match the file names `Foo', `FOO', `foo',
> `fOo', etc. The pattern `*foo*` will also match a file called
> '.foobar'.
I suspect the reason the find failed is because synapps modules have
moved on from using *Include.dbd files to putting a *_DBD list in the
Makefile, but that the autosave documentation hasn't caught up with that
change to the build configuration. I haven't checked that though.
- Andrew
> On 10/26/2017 08:11 AM, Sobhani, Bayan wrote:
>> The autosave documentation mentions adding ‘include “asSupport.dbd”’ to
>> iocxxInclude.dbd. However, when I type ‘find . -iname "*include*"’ in
>> the IOC’s top directory it returns nothing. What do I do if
>> iocxxxInclude.dbd doesn’t exist? Is there a way to get the IOC to
>> generate this file?
>> Alex
- iocxxxInclude.dbd Sobhani, Bayan
- Re: iocxxxInclude.dbd Rod Nussbaumer
Controls Engineer Job at Brookhaven NSLS-II New York, USA Farnsworth, Richard
<2017>
<2017>
