Subject: RE: Compile error with areaDetector
To: 'Jörn Dreyer' <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 15 Nov 2017 16:18:05 +0000
Hi Jörn,
I have successfully built EPICS-CPP-4.6.0 and the master branch ntndArrayConverter.cpp with the following versions of gcc:
gcc (GCC) 4.2.1 (SUSE Linux)
gcc (GCC) 4.4.7 20120313 (Red Hat 4.4.7-18)
gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-16)
You are getting an error with 4.8.4.  This seems strange since it builds OK for me with 2 versions of gcc that are older than yours, and one version that is slightly newer.
Are you sure you are using the released version of EPICS-CPP-4.6.0?
I believe my version of EPICS-CPP-4.6.0 is the distribution version, but with minor changes to these 2 files to fix issues with Visual Studio 2015.
exampleCPP/exampleClient/src/examplePvaClientPut.cpp
exampleCPP/exampleClient/src/examplePvaClientProcess.cpp
These changes are discussed on the Known Issues page:
http://epics-pvdata.sourceforge.net/docbuild/4.6.0/issues.html#c++_module_issues
There is no mention there of the types of errors you are getting.
-----Original Message-----
Sent: Wednesday, November 15, 2017 7:55 AM
To: [email protected]; Mark Rivers
Subject: Re: Compile error with areaDetector
Hi Mark,
I did a checkout from git with the master branch.
But the same happens if I checkout R3-1.
Jörn
Am Mittwoch, 15. November 2017, 14:05:19 CET schrieb Mark Rivers:
> Which version of ADCore?
> ________________________________
> From: Jörn Dreyer <[email protected]>
> Sent: Wednesday, November 15, 2017 6:58 AM
> To: Mark Rivers
> Cc: [email protected]
> Hi Mark,
> I'm using:
>  $gcc --version
> gcc (Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4
> $ lsb_release -a
> No LSB modules are available.
> Distributor ID: Ubuntu
> Description:    Ubuntu 14.04.5 LTS
> Release:        14.04
> Codename:       trusty
> Regards,
> Jörn
> > Hi Jörn,
> > I don't have experience with gcc 5.4.0.  But you say you are also getting
> > an error with gcc 4.8.  I am running gcc 4.8.5
> > and ntndArrayConverter.cpp compiles fine for me with that compiler.
> > Exactly which version of gcc 4.8 is failing for you?
> > Mark
> > From: [email protected] <[email protected]> on
> > behalf of Dreyer, Dr. Joern <[email protected]> Sent: Wednesday, November
> > 15, 2017 1:26 AM
> > Subject: Compile error with areaDetector
> > Hi,
> > I have run into a problem with areaDetector compilation when enabling
> > EPICS4 using version 4.6.0 on Ubuntu16.04.3 LTS.
> > Thanks,
problem solved. I used a different system to get acces, which did not have my
public ssh key installed in ~/.ssh. nAfter copying the key from another
system, it worked!
> > ../ntndArrayConverter.cpp: In member function ‘void
> > NTNDArrayConverter::fromUndefinedAttribute(epics::pvData::PVStructurePtr)’
> > ../ntndArrayConverter.cpp:497:54: error: no matching function for call to
> > ‘std::tr1::shared_ptr<epics::pvData::PVField>::reset() const’
> >    dest->getSubField<PVUnion>("value")->get().reset();
> > In file included from /usr/include/c++/5/tr1/memory:50:0,
> >    from
> > /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/sha
> > re dPtr.h:124, from
> > /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvT
> > yp e.h:41, from
> > /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvD
> > is play.h:14, from
> > /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/normativeTypesCPP/includ
> > e/ pv/ntndarray.h:17, from ../ntndArrayConverter.h:2,
> >    from ../ntndArrayConverter.cpp:4:
> > /usr/include/c++/5/tr1/shared_ptr.h:644:7: note: candidate: void
> > std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp =
> > epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp =
> > (__gnu_cxx::_Lock_policThanks,
system, it worked!
y)2u] <near match>
> >    reset() // never throws
> > /usr/include/c++/5/tr1/shared_ptr.h:644:7: note:  passing ‘const
> > PVFieldPtr* {aka const std::tr1::shared_ptr<epics::pvData::PVField>*}’ as
> > ‘this’ argument discards qualifiers
> > /usr/include/c++/5/tr1/shared_ptr.h:649:9: note: candidate: template<class
> > _Tp1> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*) [with _Tp1 =
> > _Tp1; _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp =
> > (__gnu_cxx::_Lock_policy)2u]
> >    reset(_Tp1* __p) // _Tp1 must be complete.
> > /usr/include/c++/5/tr1/shared_ptr.h:649:9: note:  template argument
> > deduction/substitution failed:
> > ../ntndArrayConverter.cpp:497:54: note:  candidate expects 1 argument, 0
> > provided
> >    from
> > re dPtr.h:124, from
> > yp e.h:41, from
> > is play.h:14, from
> > /usr/include/c++/5/tr1/shared_ptr.h:658:9: note: candidate: template<class
> > _Tp1, class _Deleter> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*,
> > _Deleter) [with _Tp1 = _Tp1; _Deleter = _Deleter; _Tp =
> >    reset(_Tp1* __p, _Deleter __d)
> > /usr/include/c++/5/tr1/shared_ptr.h:658:9: note:  template argument
> > ../ntndArrayConverter.cpp:497:54: note:  candidate expects 2 arguments, 0
> > provided
> > The used gcc version is 5.4.0. On Ubuntu 14.04.5 LTS The error comes at
> > the
> > same line, but different problem:
> > ../ntndArrayConverter.cpp:497:54: error: passing ‘const PVFieldPtr {aka
> > const std::tr1::shared_ptr<epics::pvData::PVField>}’ as ‘this’ argument of
> > ‘void std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp =
> > (__gnu_cxx::_Lock_policy)2u]’ discards qualifiers [-fpermissive]
> > here the used gcc version is 4.8. It look like an explicit typecast is
> > necessary here. But what would be the correct type?
> > Regards,
> > Jörn
Re: Compile error with areaDetector Jörn Dreyer
Compile error with areaDetector Dreyer, Dr. Joern
Re: Compile error with areaDetector Mark Rivers
Prev: Re: Compile error with areaDetector Jörn Dreyer
Next: RE: Problem when formating a field as HEX32 Mark Rivers
Next: Re: Compile error with areaDetector Jörn Dreyer
