Subject: Re: Problem when formating a field as HEX32
To: Mark Rivers <[email protected]>, 'Pilar Gil Jaldo' <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 15 Nov 2017 16:50:09 +0000
> I think you are probably correct that it is an issue with CSS.
Right.
In separate communication Pilar tried changing the BOY 'Connection Layer' preference from pvmanager to utility_pv or vtype_pv, which are both fine.
Only with pvmanager does he see the value modifications.
-Kay
Problem when formating a field as HEX32 Pilar Gil Jaldo
RE: Problem when formating a field as HEX32 Mark Rivers
Re: Problem when formating a field as HEX32 Pilar Gil Jaldo
Re: Problem when formating a field as HEX32 Mark Rivers
Prev: RE: Problem when formating a field as HEX32 Mark Rivers
Next: EPICS Qt release 3.5.2 Andrew C. Starritt
Next: AKTA pure James Rezende Piton
