Subject: Re: issue with either camonitor or pcaspy in 3.15?
To: Wang Xiaoqiang <[email protected]>, EPICS tech-talk <[email protected]>
Date: Sat, 18 Nov 2017 18:47:26 -0800
On Fri, Nov 03 2017, Wang Xiaoqiang <[email protected]> wrote:
> Here is my test on linux-x86_64 arch, using pcaspy 0.7.0 anaconda
> package from https://anaconda.org/paulscherrerinstitute/pcaspy
> It does not reproduce the problem. Any chance that you could test using
> the same setup?
Hi, Xiaoqiang.  Thanks for confirming for me.  I finally figured out
what the issue was.  In my test pcaspy IOC, on init I am attempting to
clear the "UDF INVALID" flags with the following:
     for k in pvdb:
         driver.setParamStatus(k, pcaspy.Severity.NO_ALARM, pcaspy.Severity.NO_ALARM)
In earlier pcaspy versions this was sufficient to clear the flags
without causing any additional odd behavior.  I see now that with 0.6
and later the issue I need to additionally call updatePVs() after the
above:
     driver.updatePVs()
Is this the right thing to do?  Is there a cleaner way to clear the
initial "UDF INVALID" flags?  And why is the "UDF INVALID" set
initially anyway?
Thanks so much for the help.
jamie.
Attachment: signature.asc
Description: PGP signature
Re: issue with either camonitor or pcaspy in 3.15? Wang Xiaoqiang
issue with either camonitor or pcaspy in 3.15? Jameson Graef Rollins
Prev: Re: areaDetector and HDF5 file saving segafaults Mark Rivers
Next: Illunis CMV-50 camera & Kaya Custom Fiber framegrabber neil.o'brien
Prev: Re: issue with either camonitor or pcaspy in 3.15? Wang Xiaoqiang
Next: Re: issue with either camonitor or pcaspy in 3.15? Wang Xiaoqiang
