Subject: Re: time stamp on vxWorks jumping to the future
Date: Tue, 28 Nov 2017 22:41:31 +0000
Am 28.11.2017 um 18:35 schrieb Andrew Johnson <[email protected]>:
On 11/28/2017 11:03 AM, Hartman, Steven M. wrote:
On Nov 27, 2017, at 9:04 PM, Michael Davidsaver <[email protected]> wrote:
On 11/27/2017 02:47 AM, Dirk Zimoch wrote:
Can a corrupted NTP message cause this?
This depends on how much, if any, validation is done by sntpcTimeGet().
Very little validation. Nothing to check if the reported time is sensible as compared to the previously known local time.
I have added a sanity check now in my copies of EPICS 3.14.8 and .12 to refuse 1 hour+ jumps and log an error message instead. Let‘s see what I get ...
Dirk, what type of device is your NTP server and where does it get its time? I recall that SNS had a GPS for the timing system which worked fine for the timing system’s time stamp, but it wasn’t considered reliable to use as an NTP server. Can you monitor what your NTP server is reporting?
No idea. My NTP server is the network router for our subnet from PSI IT department. Before I blame them I want to have proof. 😉
This might be completely irrelevant to this issue, but at APS we
discovered that running ntpd on RHEL7 on a VM the times given out to NTP
clients were really noisy (ntpd doesn't understand hypervisors). By
switching to the newer Chrony package we got much nicer results, the
server locks much more quickly and closely than ntpd (Chrony doesn't
support the same obscure high precision clock hardware that ntpd does,
but we don't need them).
- Andrew
We had time problems on SL6 VMs because the virtual machine did not understand clock throttling of the physical host. That is solved now, basically using the vmware tools properly. But this is unrelated.
time stamp on vxWorks jumping to the future Dirk Zimoch
Re: time stamp on vxWorks jumping to the future Dirk Zimoch
Re: time stamp on vxWorks jumping to the future Michael Davidsaver
Re: time stamp on vxWorks jumping to the future Hartman, Steven M.
Re: time stamp on vxWorks jumping to the future Andrew Johnson
Prev: RE: EDM Hoff Video Widget and Bits Per Pixel Mark Rivers
Next: Tab Container set focus Amien WORK
Prev: Re: time stamp on vxWorks jumping to the future Andrew Johnson
Next: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile? Jörn Dreyer
