Subject: Re: EPID bumpless restart
To: "Crisp, Daniel" <[email protected]>
Cc: "[email protected] list" <[email protected]>
Date: Wed, 29 Nov 2017 21:38:05 +0000
> 2)      How to best implement a deadband? (It appears there was a thread about the ODEL field being present, but not used in the epid support code? Am I wrong? Is this still the case?)
> Especially for some magnets that require a less frequent touch, I’d like the epid to only act on the supply when the error reaches a larger percent difference. Specifically, I’d like it to only react to errors in field greater than, say, .01% of the target field. We had tried to simply decrease the KP value enough that resulting P values are less than what can be acted on by the supply (supply doesn’t recognize a difference in set points differing by the 3rd significant figure), but this isn’t ideal.
I had the same issue. We use the ePID record to control a needle valve on our cryostat systems (to control the flow of Helium). In the end I implemented a database wrapper around the ePID that has a deadband and a timer. If the error is within the setpoint deadband, and has been for X seconds, then I disable the control using FBON. The timer part is important, otherwise the control will be disabled as soon as the error reaches the edge of the deadband.
Cheers,
Matt
EPID bumpless restart Crisp, Daniel
Prev: EPID bumpless restart Crisp, Daniel
Next: Release or Tags in epics-modules Jeong Han Lee
Next: RE: EPID bumpless restart Mark Rivers
